Front alignment issue + "clunk"-UPDATE
Under the Lift
Yes, it may not be the source of your "clunk" but that LCA is junk. I installed some 928 Intl rebuilt ones a few months ago on another 928. My lord, the fresh, uncompressed rear bushing is huge and requires a lot of coaxing (floor jack underneath) to get into the mount enough to allow the lower bracket and bolts to go on.
Finally getting a chance to update this saga. I took the car back to the local Sears place and walked the tech through the alignment process. He was thinking there were stops on the camber and caster adjusters. Once we loosened the caster adjusters he was able to get the camber adjusters to turn around where they need to be. My front alignment is now in perfect spec. I still need to change the rear upper arm bushings to bring the rear camber in to spec but a little excess camber is not bad. Thanks to everyone here for the suggestions and feedback. I've got a few more issues to address before getting the new LCA's for the front. I just keep chipping away at it and the list gets smaller each month.
Mike
Mike
Mike
Mike
Holy crap, don't get an alignment from them again.
Mike
Rest in Peace
Take the car to a body shop and check the frame for up to a 1" bow up from a bounce. Everything you are saying happened to me, and I found out my car had taken a perfect bounce and bent the front clip up 1" wrt normal height and angle. It was only $400 to bring it back straight, but the rest of the bind was the column and the knuckle had to be replaced. I had already replace NOS the upper A-arms, rack, tie-rod ends, springs, and shocks/struts.
Cheers,
Andre
Cheers,
Andre
