928 Forum 1978-1995
Sponsored by: 928 Specialists
Tensioner gasket PN?
Old Sep 26, 2011 | 12:29 AM
BigAl1's Avatar
BigAl1
Default Tensioner gasket PN?
After checking PET, and 3 online sites, I can't find the PN for the timing belt tensioner gasket for the 78-81 style tensioner. Anybody know it?
Old Sep 26, 2011 | 12:46 AM
MainePorsche's Avatar
MainePorsche
For an 87 it is 928.105.611.05.
The tensioners look to have the same configuration, but you should verify.
Mark Anderson's Avatar
Mark Anderson
The Parts Whisperer
Technically speaking the 78-81 did not use a gasket
Old Sep 26, 2011 | 07:03 AM
gbgastowers's Avatar
gbgastowers
No gasket from block to tensioner mounting surface and none inside. Just the rubber boot over the nose and some sealant on the threads of the tension adjustment bolt. Gunar
Old Sep 26, 2011 | 09:24 AM
BigAl1's Avatar
BigAl1
Thanks Mark and Gunar.
