Oil Galley Plugs
08-21-2011 | 12:52 AM
Rest in PeaceRennlist Member
Quote:
Originally Posted by
Mrmerlin
these plugs are one time use,
once they are installed and then removed,
then they have to be replaced
You can reuse them, they will just leak like hell.
08-21-2011 | 05:00 AM
Upgrade to the new style pins for the rear cam journals too.
08-21-2011 | 09:47 AM
Lizard931
You mean those new pins I put in that replace the rubber plugs with the pins in them?
08-21-2011 | 09:49 AM
jeff spahn
I got the plugs installed. Have to redo one head because I put one in too far and the galley is exposed. Prolly gonna pull all 6, clean again and reinstall.
I should have clarified. I am going to pull all 6, clean again and reinstall
NEW PLUGS.
08-21-2011 | 09:53 AM
jeff spahn
Yes
08-21-2011 | 10:58 AM
funny how leaving out a few words can change the intent your trying to create,
01-11-2012 | 03:55 PM
AddictLifetime Rennlist Member
jeff spahn
These. 6 per head.
Jeff: what is routed through the bracket on the head ?
Edit: Never mind. This must be the back of the right side head.
01-11-2012 | 09:11 PM
Leon Speed
Yes. It is the backside of the head and the connector for the exhaust gas temp clips in there.
57 ,
928s4 ,
944 ,
core ,
find ,
freeze ,
galley ,
install ,
oil ,
plug ,
plugs ,
plugs924 ,
porsche ,
tools ,
water
