I bet you probably know but I'll state it anyway. Don't put any assembly lube on the backside of the rod bearing(can cause spun rod bearing) or too much on the face(tight tolerance).
PS, one more tip I'd come across in my reading was to wrap the end of the rod when dropping the piston in to avoid possibly damaging the cylinder walls. No idea if this is common practice, but figured I'd toss it out there just in case.
I used pieces of rubber hose for this. The bolts will score the crank also without the covers. Gunar
why would you take the piston out from the bottom? if you have to put it in through the top, why not just push it out the top??
what am i missing here??
Mark
Jerry was messing with me because I was trying to do a Dwayne style write up on changing out a piston and wasn't clear about taking out the top of the block so he and Rob turned it into a pretty good joke with the photo of the piston trying to leave the bottom of the bore.
