928 Forum 1978-1995
Sponsored by: 928 Specialists
Piston Swap
Old 08-09-2011, 05:20 PM
jeff spahn
jeff spahn's Avatar
Default Piston Swap
AADDPP requested that I take pictures and document ala Dwayne what I am doing when doing a piston swap.
I'll make an attempt at it:
First we assume you have the engine out of the car, on a stand with the heads off and the oil pan off.
Loosen the connecting rod nuts with a 14mm 12 point socket:
Then remove the cap and bearing from the connecting rod. Be sure to note the orientation of the cap. I don't know if they go one way or there other but if you put it back on the same direction it came off, you can't be wrong. Then push (or pull depending on the orientation of the block up or down on your stand) the piston out of the block where the heads used to be (that's to help you Jerry)
Now you can change the rings and move the connecting rod from your old piston over. This is as far as I got at lunch today so I'll post more tonight after I get back from a bike ride.
Old 08-09-2011, 05:47 PM
Lizard928
Lizard928's Avatar
I would recommend re-using the connecting rod and then match the weight of the old piston to new.
Old 08-09-2011, 06:06 PM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,556 Likes on 1,235 Posts
Rod caps definitely need to go on the way they came off. The factory provides some convenient markings:
Old 08-09-2011, 06:09 PM
mark kibort
mark kibort's Avatar
what is wrong with that piston?? is the coating gone on the sides or something? holes in it? ring lands damaged?
I would also do what was suggested. re use the rod, weigh both pistons and match the weight by taking weight off the piston in a way that cant structually hurt it. if its too light already, there is not much you can do then.
Old 08-09-2011, 06:15 PM
jeff spahn
jeff spahn's Avatar
Mark
The piston top is very damaged and full of big nicks and dings. Figured it would be best to replace it rather than run it damaged. Don't want to chance it breaking. Looks like it ate a washer or something. I'll post close ups of the piston in this thread tonight.
If you want it I'll send it to you for the cost of shipping.
Old 08-09-2011, 07:06 PM
jeff spahn
jeff spahn's Avatar
The pistons are within 4g of each other in weight. Is that close enough? New one is heavier.
Old 08-09-2011, 07:11 PM
Jerry Feather
Jerry Feather's Avatar
Ok, Jeff, I did what you said. I got the engine out and put it on the stand, then took the oil pan off. Then I used the same kind of wrench on the rod bolts and got the rod cap off, but for the life of me I cannot get the damn piston to come out past the crank and all that other stuff in the way. I must have missed a page or two of the instructions.
Jerry Feather
Old 08-09-2011, 07:17 PM
Rob Edwards
Archive Gatekeeper
Jerry-
If you bend the old connecting rod over 90o, then rotate the crank around just so, you can just barely squeeze the piston out through the bottom:
Old 08-09-2011, 07:28 PM
Jerry Feather
Thanks Rob. That Helps. That must have been on one of the missing pages of instructions.
What do you use to bend the rod with. Where should the bend be made. Do I have to bend the new rod also before I can get the new piston back in. How do I straighten the new rod out after it is back in.
Is there any trick to "squeezing" the piston? Is that how the hammer marks got on your crank case? How big a hammer do I use for the squeeze.
I'm pulling you chain, of course. Dwayne is a tough act to follow and we are a ways short of his kind of tutorial here.
Jerry Feather
Old 08-09-2011, 09:19 PM
jeff spahn
jeff spahn's Avatar
You are funny Jerry. I read that and laughed out loud and my friends gave me strange looks til I read them your reply. I'll edit the post tonight when I get home.
Old 08-10-2011, 03:00 PM
aaddpp
aaddpp's Avatar
Jeff, thanks for posting the photos and the steps that you followed. Looks pretty straight forward, though its still intimidating to consider doing this the first time. Hopefully everything goes well from here forward with your repair.
Thanks again, Dave
Old 08-10-2011, 04:32 PM
jeff spahn
jeff spahn's Avatar
Dave. Really taking out the piston is super easy. I was pleasantly surprised by how much of a non-event it really was. Taking the engine out wasn't really that bad either. Last engine I did was in a 76 Buick Century. Granted there are a lot more connections on this engine but it isn't that bad. Something I did find I had to do to get the engine out was not only unbolt the engine from the bell housing but also unbolt the bell housing from the torque tube. The flywheel was catching on the bell housing edge and not letting it come out. One that was free, engine came right out. I imagine installation is just gonna be reverse of removal. I am going to totally assemble the engine on the stand and then put it in instead of working around the cramped underhood area.
Old 08-10-2011, 09:21 PM
gbgastowers
gbgastowers's Avatar
Location: Holden Beach and Winston-Salem, North Carolina 82 928 Euro S 5spd MOSS GREEN/CHAMPAGNE-04 996 C4S CONV TIP POLAR SILVER/METROPOL BLUE
Can you post a pic of your rod bearings and what piston/bore # it is? Thanks- Gunar
Old 08-10-2011, 10:26 PM
jeff spahn
jeff spahn's Avatar
Gunar
It is piston #5 (driver's side front).
Here are the bearings. You can see there is a very tiny score in the bearing. There is no score in the crank. I have a new bearing coming for this rod.
I am having the piston weight matched to the old one. Should be able to get it to less than 1/2 a gram when all done. Piston's had holes drilled but we are off by 9 grams right now due to different weights in the wrist pins. Gonna balance everything out at the shop tomorrow. Should have together and running (hope) by Sunday.
Old 08-10-2011, 10:45 PM
gbgastowers
Originally Posted by jeff spahn
Gunar
Attachment 558314
Attachment 558315
Thanks for the info- I reused the best rod bearings from 2 identical engines when I was in where you are now. They all looked as good as the one in your picture or better. So far so good. This is open heart surgery and is very satisfying when all goes well. This forum made it doable for even a virgin like me. Take your time and enjoy. Gunar
Quick Reply: Piston Swap
