928 Forum 1978-1995
Sponsored by: 928 Specialists
928 Key light
Old Aug 9, 2011 | 01:59 PM
Doug_B_928's Avatar
Doug_B_928
Default 928 Key light
Searched and saw several threads about LED conversion, but none about just getting standard set-up to work. Sorry if I missed it. I have a new battery and bulb from Roger. Battery tests OK. But bulb still doesn't come on. I tried the battery directly against the bulb and directly against the copper piece, still nothing. The pic is the best focus my camera would take, sorry about that. Is there anything missing (other than my understanding of how this works)?
Thanks,
Doug
79 5 speed
File Type: jpg
Old Aug 9, 2011 | 04:17 PM
dprantl's Avatar
dprantl
If you have a new bulb and battery and it still doesn't light, you need to clean all the electrical contacts carefully and thoroughly. Looking closer at the pics, it seems you may also be missing a contact piece, the one that makes contact with the base of the bulb.
Dan
'91 928GT S/C 475hp/460lb.ft
Old Aug 9, 2011 | 05:25 PM
Doug_B_928's Avatar
Doug_B_928
Thanks, Dan. I'll PM Roger to see if he has the missing part.
Doug
Old Aug 9, 2011 | 05:35 PM
Green Goblin's Avatar
Green Goblin
What type of battery is used in the key??????????
Andy
Old Aug 9, 2011 | 05:37 PM
Doug_B_928's Avatar
Doug_B_928
It's a Varta V625U - LR9 Alkaline 1.5V
Doug
Old Aug 9, 2011 | 08:45 PM
ROG100's Avatar
ROG100
Basic Sponsor
Doug,
Dan is right you are missing the rear contact.
Roger
File Type: jpg
Old Aug 9, 2011 | 09:07 PM
Doug_B_928's Avatar
Doug_B_928
Thanks, Roger. Do you have that piece? If not, is there anything special about it or is it something I can manufacture?
Old Aug 9, 2011 | 09:26 PM
dprantl's Avatar
dprantl
It is just a thin piece of copper that connects the base of the bulb to the side of the battery. I don't see why you couldn't bend up something to fit in there.
Dan
7 Porsche Models That Have Aged Like Fine Wine
Old Aug 9, 2011 | 09:30 PM
Doug_B_928's Avatar
Doug_B_928
Okay, thanks Dan. I'll see what I can come up with and give it a go.
Doug
Old Aug 9, 2011 | 11:25 PM
martinss's Avatar
martinss
I have a newer style key. I just replaced the head which came with a working light and battery and is a lot less battered. The blade just clicks in. Here's what the disassembled inside looks like alongside the new one:
Old Aug 9, 2011 | 11:35 PM
Doug_B_928's Avatar
Doug_B_928
Neat! I wasn't aware of that option. From which supplier did you get it?
Doug
Old Aug 9, 2011 | 11:46 PM
martinss's Avatar
martinss
Doug
eBay: http://cgi.ebay.com/ebaymotors/ws/eB...m=140584968858
They also have blank blades. I don't see a head in your style tho.
Old Aug 10, 2011 | 01:41 PM
ROG100's Avatar
ROG100
Basic Sponsor
Doug,
The lighted key head above is for the later style.
Either make a piece to fit your key or have a new style blank made by www.keys4classics.com.
Roger
Old Aug 10, 2011 | 05:34 PM
Chuck Schreiber's Avatar
Chuck Schreiber
Doug,
You should be able to just buy a new key head and put it on your 79 key.
They are about $15 bucks. BUT, I will bet you a buck that in a few months, your light/battery will barely work. I went through several until I upgraded to the LED. Sounds like you don't want to, but just in case you do:
I posted this a while back:
I got sick of the nasty key that lost its crest a while back and never did light up like it was supposed to.
So, I treated GTS to a new key head and key chain.
Also, did the LED upgrade to the key head based on a couple of good links I found via Rennlist.
Key Head
http://www.pelicanparts.com/techarti...lt_keyhead.htm
LED upgrade to Key Head
http://p-car.com/diy/key/
(scroll down to second article)
The key head is about $15 from the Porsche store.
The batteries are about $10 from batteries plus
The LED is about $5 from Radio shack.
Takes about 20min for the whole thing.
I ended up doing 2 keys and it’s WAAAAY brighter than the original key head. (If yours even works)
If nothing else, the first link should give you a little help w the new key head.
Good luck!!
File Type: jpg
File Type: jpg
File Type: jpg
Old Aug 10, 2011 | 05:54 PM
Doug_B_928's Avatar
Doug_B_928
Hi Chuck,
It wasn't my original intention, but now I'm searching for an appropriate piece of copper and I'll be manufacturing anyway. I'll probably get it working old school since I have the new bulb and battery, but, if it doesn't last long as you suggest, I'll likely try to upgrade it to LED at that time. It certainly looks very nice in your pics. Would the LED upgrade work on the existing 79 key head? I see you used two watch batteries. I assume the existing Varta one isn't enough?? Do you think the two watch batteries would fit in the existing head, or does one need the new head?
Thanks,
Doug
79 5 speed
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
