928 Forum 1978-1995
Sponsored by: 928 Specialists
Clean engine interior?
Old Aug 8, 2011 | 03:18 PM
mallman's Avatar
mallman
airplane acid makes aluminun white like this.
Old Aug 8, 2011 | 03:29 PM
GregBBRD's Avatar
GregBBRD
Former Vendor
Originally Posted by jeff spahn
I am not taking the girdle off the block. I am only taking one piston out to replace a dinged/damaged one and then putting the engine back together. New conn rod bearings on that piston as well. Just wondered about all the oil and such if I should just wipe it down or clean with something. Not going to take whole engine apart unless my conn rod bearing on the one piston shows it is super worn.
If this is the case, I'll start another thread and begin there.
So, let me get this right. 150,000 miles on an automatic 928 and you aren't going to look at the main bearings and only one rod bearing.
Hmmm.
Old Aug 8, 2011 | 03:30 PM
Rob Edwards's Avatar
Rob Edwards
Archive Gatekeeper
Actually, that block was acid dipped in the process of being Nikasiled, I spent literally 2 days cleaning it to get it to what you see, and even then Greg busted out the water and the toilet brush on the bores. Pretty sure I wouldn't do the toilet brush thing on a stock block cylinder bore, shoulda pointed that out in the previous post.
Old Aug 8, 2011 | 04:37 PM
jeff spahn's Avatar
jeff spahn
Originally Posted by gbgastowers
I thought you bought another block from Carl. A nikasil coated one. What are you going to do with it? Gunar
https://rennlist.com/forums/928-foru...ew-engine.html
I did have another block but in further discussion with Carl we decided to just use the old block rather than go down the road of a new engine.
Old Aug 10, 2011 | 12:35 PM
Carl Fausett's Avatar
Carl Fausett
Developer
Replace all the rod bearings. Its a great way to get more oil to the mains, and take slop out of the rods. You willnot be able to buy just 1 rod bearings anyway, so put them all in. You can do this without removing the cradle. You can even do it on your back with engine in the car....
Be careful cleaning gasket surfaces with a razor blade, you can carve it like basswood. Skotchbrite pads do a better job and are safer.
And because its an automatic - check the thrust bearing (the center main) for wear. Good time to replace the flex plate clamp!
http://www.928motorsports.com/parts/...haft_clamp.php
Old Aug 10, 2011 | 10:27 PM
fraggle's Avatar
fraggle
I have a set of PLASTIC razor blades for my scraper that I use for stuff like this. Check your local auto parts place.
Old Aug 10, 2011 | 10:31 PM
jeff spahn's Avatar
jeff spahn
So what you are saying is using the wire brush attachment on on 1/2" drill is a bad idea? JK
Old Aug 10, 2011 | 11:25 PM
jeff spahn's Avatar
jeff spahn
Originally Posted by Rob Edwards
I'll throw this out, with the caveat that I haven't actually done this....
I think I'd start by making sure your cylinder decks are completely clean and free of old gasket. Fill each cylinder with oily rags to minimize the crap getting in them. Then if you haven't already, make sure that each head bolt hole is completely clean and dry- blow 'em out with compressed air and run many, many brakekleen-soaked shop rags on a gun barrel cleaning rod. Those threads are under huge stress and they'd better be clean. Then I'd clean out the schmutz from each cylinder again, wipe down the deck several times to make it spotless and oil-free, and install the head for that side. Repeat the process for the other head.
Are the heads going out to get decked? Hope so.
Did you/have you measured crank endplay? On a 150K+ mile motor out of an automatic (even one with as good a maintenance history as yours) I think I'd want to make sure the thrust bearing is happy before sealing everything up. And at the very least I'd replace all the rod bearings. Torque the con rod nuts well....
Checked the endplay tonight .21mm. Well within factory new specs. Happy about that.
Old Aug 11, 2011 | 12:17 AM
Mrmerlin's Avatar
Mrmerlin
Team Owner
FWIW if you use a fresh razor and hold it perpendicular to the surface it will be impossible to make any gouges, if you hold it at a 45 degree angle then yes you can make small imperfections in the surface.
With the razor at 90 degrees to the surface it simply cant dig in but it will neatly remove particles that are above the surface.
Use a back and forth motion on the fresh razor and change them frequently.
This works very well on removing the loctite 574 from the girdle sealing areas
FWIW the scotch brite pads will also leave behind microscopic abrasive as they fall of the pad i wouldnt be using these on the engine.
FWIW if you get the crank polished then you must clean it thoroughly this may take 4 cans of brake cleaned applied to all of the throws in the crank , a oil bore brush
then a thorough washing with simple green and hot hi pressure water.
NOTE the throws will fill up with polishing compound and if they are not removed there is high probability that the bearings will fail from this polishing compound being released when the oil is hot and forced into the journals.
Old Aug 11, 2011 | 11:27 AM
Carl Fausett
Developer
You might find this article useful:
Follow this link: http://www.928motorsports.com/install.php
and download "Engine Preassembly" from the Engine Products section of that page.
