Clutch Removal - 90' GT
#31
Supercharged
It looks like the clamp has already moved back an inch or two. You might check to see if a torque tube bearing is preventing it from sliding back further. You can use a length of wire coat hanger to see if there is anything in the way. If not, use doc's suggestion and spread the clamp with a screwdriver and then slide back. If there is something in the way... then you probably need to drop the TT.
#32
I managed to slide it back far enough; it wasn't quite sprung open enough at first and I couldn't seem to find a suitable lever to push it back...until I tried the versatile and marvelous PKBumpstick tool
#33
