Pic request - GTS windshield corner
Can someone pls post a pic of the top corner of their windshield - either a GTS or a car with GTS side seals.
I just replaced my trim and seals with the GTS versions that include the corner seal, but I'm pretty sure the seal was molded incorrectly.
Before I cut it, I'd like to see a pic to make sure.
Thanks!
Thanks!
Archive Gatekeeper
The Wurth rep brought you more HHS-K, Greg?
Archive Gatekeeper
Was I going to get some thing for you?
On Topic: George, I'll shoot pics to add a datapoint, later tonight.
I believe he is referring to the one you have the arrow identifying. In your picture it is very hard to see due to the lack of contrast between it and the lower side trim and windshield.
Archive Gatekeeper
Uno mas:
Here are some more pic's... First, the '90 GT which we fitted with GTS trim last fall.
I shaved down the bit that tucks under the top trim (the side against the glass, with a razor blade), the abrupt edge didn't seem right.
And here is the '93 GTS, untouched since Fritz assembled the windshield frame in '92.
It looks like they tucked the "tail" in a bit, on one side. The driver's side looks a bit funky.
(Yes, it's dirty... Black always looks dirty. And it gets driven )
I assume this is to reduce wind noise and improve the appearance? If so, does it make a noticeable difference and is it a worthy upgrade for earlier models?
