928 Forum 1978-1995
Sponsored by: 928 Specialists
Pic request - GTS windshield corner
Old 07-27-2011, 12:21 AM
RKD in OKC
RKD in OKC's Avatar
Jarrod - Yes, Dumont recommended it when I complained about the high speed wind noise on the 90 GT.
Old 07-27-2011, 12:25 AM
JWise
JWise's Avatar
Thanks! Looks like it would help. I'll have to give it a try myself.
Old 07-27-2011, 12:40 AM
blown 87
Rest in Peace
blown 87's Avatar
Originally Posted by JWise
I assume this is to reduce wind noise and improve the appearance? If so, does it make a noticeable difference and is it a worthy upgrade for earlier models?
Just make sure you hit the turkey in the trim, not on the body, takes some small degree of skill, then the insurance company will pay for the upgrade.
It does make a difference, a small one.
Old 07-27-2011, 12:55 AM
77tony
77tony's Avatar
George, The body shop lost one of mine so I ordered one from Roger. Trim Sleeve - Right 928 559 214 05 70K. Unit price $ 8.59. 77Tony
Old 07-27-2011, 01:38 AM
Dave928S
Dave928S's Avatar
Here's a pic of mine. The little wedge on the outside is showing the same gap at the bottom as the previous pics, and the rubber under the trim at the top is pushed back under on both sides so you don't notice the abrupt finish instead of a taper. Mine has had a new screen, so it's possible that these haven't been correctly replaced.
Now I'm going to have to pull that top trim off and see, as there's also a rubber strip floating around under there that looks like it's not down to the lower edge as it should be.
Old 07-27-2011, 02:02 AM
jcorenman
jcorenman's Avatar
It does reduce the wind noise, but price it out first. You need new metal trim on the sides, as well as the rubber inserts. ...
Old 07-27-2011, 05:01 AM
StratfordShark
StratfordShark's Avatar
Completely eliminated windshield noise on my S4 - great upgrade. I don't think I had to replace the metal trims, but I had a spare pair anyway so used them to make all look like new.
Old 07-27-2011, 07:45 AM
Herman K
Herman K's Avatar
Default There is a 6mm seal
There is a 6mm square seal that's located under the top trim and it runs all the way across and meet the corners on each side. The corner trim ends are about the same square shape and meet this seal on either side where they get glued together so they form one seal.
There’re detailed drawings of the upper trim with the this 6mm square seal in the WSM glass replacement section
Removing the top trim without distorting its shape is a challenge and I thinks it will be better to have a new one on hand (about $130) before you get started.
Ask me how I know
Old 07-27-2011, 08:28 AM
shadowknight
shadowknight's Avatar
I added the rubber to my s4 it did not require new trim.
Old 07-27-2011, 09:08 AM
GeorgeM
GeorgeM's Avatar
That's what I did. My seals were in crap shape, corners seals gone and I figured if going to the trouble, may as well just replace everything.
When we pulled the side seals out (they were hollow), they were full of water and nastiness.
Old 07-27-2011, 09:59 AM
blown 87
Rest in Peace
blown 87's Avatar
I had to replace all my trim on my S4 to do it.
I also think that the S4 trim is NLA, at least part of it.
Old 07-27-2011, 02:38 PM
GeorgeM
GeorgeM's Avatar
I replaced everything but the top trim clips, which are riveted to the roof panel and can only be replaced with the glass out.
Old 07-27-2011, 06:33 PM
oaros
oaros's Avatar
Default Seal?? What seal?
Commando style (aka the hidden costs of PO's cheap respray)
Old 07-27-2011, 07:21 PM
Dave928S
Dave928S's Avatar
Ask me how I know
Thanks Herman ... I'll add that job to the ever growing list.
I'll also add windscreen replacement 'experts' to my hate list, along with the alarm, radio and phone 'experts".
Old 07-28-2011, 09:21 AM
finally!
finally!'s Avatar
I am curious as well.. and pricing and difficulty of removal and install
Quick Reply: Pic request - GTS windshield corner
