PKLAMP INSTALLATION
can anyone breakdown the installation of a PKCLAMP in an 1985 928S, US, AUTO into 10-15 ish SIMPLE steps.
I have read the installation instructions, but I am a bit confused about flexplate tension release and endplay measurement, and was hoping someone could break it all down into one simple post.
and to be honest, I am not really very conserned about the measurements, I just want to get it in for piece of mind, and if every 6 months I have to open her up, loosen the clamp, push back the flywheel and retighten, I am ok with that.
also how do you rotate the engine with a wrench to move flexplate or torque convertor?
thanks,
thanks,
Inventor
Flex plate release: undo 1 bolt (8mm hex iirc) that holds the collar in place. If you put a straight edge on the flex plate prior to release and observe any bowing it should rebound to 'flat' on release. retorque aforementioned bolt some add blue loctite.
Endplay: is the crankshaft free play when bolted in the engine. After the above release leverage the flex plate forward (large screw driver) then with a dial guage suitable clamped with a magnetic stand zero guage, lever flex plate to rear and read guage.....this is the end play......the larger the worse, theres a spec which I dont recall.
for more detailed description Bill Ball published the end play measurement......good luck.
Captain Obvious
Super User
Super User
