Duc's Hybrid build
#197
Craic Head
Duc,
Sorry for the delay. Been a bit busy but the scoop came out good and solid, dimensionally accurate. My painting job not so much so far, but I'm hoping to get back to it soon.
#202
doing the logs by hand.
WELL. i she was running a tag rich at idle. and when i was hunting under the car for that smoke issue i found a bad collector gasket. SOOOOOO looks like i might have dyno'd the car with an exhaust leak. so everything is a tad rich.
going to start thinking on how i want to do the exhaust (to loud) and when i get that redone, i will reset the AFR and re tune. might help with power.
#203
the night of Firsts!!!
Longest i have EVER driven the car (2.5 hours)!! yay
only got 9.8 MPG... WTF? then i come to find out when i got home i have a bad collector gasket. so it was messing with my AFR tables... DAMNIT. can't WAIT for colin to get the V-band shorty headers done...
#204
9 - 10 mpg??
You got more going on than just a "little rich"... It sounded like the car ran well... it is a beautiful piece of machinery. I'm sure you'll get her sorted out lickety-split
#205
it ran great! at cruise it was around 14-14.5 AFR, sometimes high 13's. thats not horrible, but if it was reading that rich WITH an exhaust leak, could have really been around 10. thats rich. ill find better gaskets, not the cheap paper crap that was on it. i was thinking copper, but id rather get the nice graphite ones, but i need to find them local.
#206
Get an extra set and I'll buy them off of you... Mine are TOAST!!!
#208
re checked the timing today. computer says 13 advanced at idle.... timing light says 5 advanced.... SOO time to re do the timing. all everything checked out when first started, so i screwed something up... with this fixed (when i do) and a diff exhaust. i think my power numbers will be much higher on the dyno.
#209
Captain Obvious
Super User
Super User
I got a nice graphite collector gaskets at the local muffler shop. Thake an old one with you and they can match one up for you.
#210
^^ thats what i ended up getting Felpro 2001 3" collector gaskets. im amazed at the paper ones. what crap.
SOOO UPDATE!!!! my timing was uber off. i computer was set at tooth 1 at 80btc, when it should have been 60.. much better now.
