Checking for timing jump
#62
Under the Lift
Charley's 2-4% leakdown, as good as a fresh motor, was a very pleasing finding.
The belt had several paper thin slices cut off the front edge covering maybe 1/2 of belt length as well as a few gouges and cuts near the front for another 3rd of the belt length. Charley found evidence of something wedged between the belt and the inside of one cover near the front edge, but whatever it was, it was not in the area anymore. None of the teeth were sheared or showed any damage - the belt was a Porsche part. The water pump pulley was firm and spun with proper drag - water pump was a rebuilt Porsche with plastic impeller in perfect condition, although there was evidence of longterm weeping of coolant from the weep hole (bad seal - pump needs to be replaced). The tensioner arm bushings and pulley were in good shape. The tensioner had not backed off. The upper and lower idlers were free. The cam gears were in reusable condition and the spiders and cam noses were intact.
#63
Team Owner
I would be looking for something that fell or broke off of the timing cover and possibly is sitting at the bottom of the rear cover,if the belt has this damage something caused it though I dont understand how.
Its good that the compression numbers are spot on,
looks like you dodged a bullet
#65
Under the Lift
The bullet just missed.
#66
Very glad to hear this Charley! I just recently dodged a MAJOR bullet too, but mine was with a seized water pump. As I was reading through the thread waiting to hear the outcome, it didn't look good and I was starting to feel just a little guilty about my good fortune. Glad that you joined the Club (with a great assist from Bill)!!!
#67
The only evidence of disturbance I could find was a spot in the center cover where the leading edge of the belt appears to have dug into a little hump in the plastic that rises to clear the power steering mount.
#68
Team Owner
that wear mark is from the belt being loose I was really hoping that you could find something. At this point I would strongly suggest to replace the water pump with a new Laso.
even though you have what seems to be a good pump if its been rebuilt then its suspect for the bearing migrating in the bore.
Period.
I have had to replace more than few rebuilds even though the bearing turned smooth and the precipitating factor was a belt warning with no other obvious indications on how the belt got loose.
In the long run, this step will save you lots of time from redoing this job. I promise!
Period.
#69
Why are you using "temp" flat head bolts on the spider? A normal person (no disrepect) would put the allen heads back in. (Disclosure: sometimes I am so **** I try to put the bolt or screw back in the threads it cam out of, whether it is being held there for storage or til the job is completed but that isn't really what is at issue here.) I'm trying to link that to a missing "X" that damaged the belt. You have not mentioned any damage to the cam gear. If something came loose and came between the gear and the belt allowing it to jump, wouldn't there be some evidence on the gear itself? Moving on, I'm glad for your good fortune.
#70
Chronic Tool Dropper
Charley--
Great news and you'll sleep more soundly now. All that clean living has finally paid off.
#71
Team Owner
Note the Allen heads in the rotors will be too long,
shorter temporary screws should be used to hold the cam pulley to the spider so the timing isnt lost though now with a new belt the timing should be reset putting the screws could keep the timing correct if it was already set
#72
1) Awesome New York attitude, keep that.
2) I am not a normal person
3) Just because I am doing this job does not mean I know what I'm doing. I also put my chewing gum on the side of the fender before I started.
#73
Stan noted a "normal" reason, thanks for the reminder. I have used Ken's gauge, but it's been so long I forgot that feature. Would indicate I should get it out and set mine again, perhaps.
I love a good mystery, but the ones on TV, always provide the solution at the end. We aren't going to get that here.
Glad to see you saw it the way I meant it. eceteraetcetera.
