The build a 928 boat thread.
Rennlist Sponsor
Hi Dave,
Great score on getting the Nordic Tunnel, and I am glad to see you are back on the boat project!! As per our previous convos on this subject I am really excited to see your finished project!
The chance of getting a ride in a 928 powered boat could just be the catylist to get me to venture all the way up to your neck of the woods to visit you! :-)
Let me know if there is anything I have laying around you can use on the project. I would be happy to donate to the insanity...err, I mean "cause"... Ha, Ha!
Cheers,
Dave
P.S. everytime I thyink of you rigging a 928 engine in a boat... this pic comes to mind. Not a boat engine pic, just a cool 928 engine install in something besides a 928. Plus the attention to detail reminds me of your work ethic.
BTW, here are some Porsche Boat pics in case you forgot about these. Might give you some design inspiration...also note the Jet Drive in this smaller Porsche boat :-)
Cheers,
Dave
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
David Roberts
www.928gt.com
So are you going to need to fabricate some kind of connector
between the motor and the jet drive? I am assuming the current
adapter is set up for a Chevy. It's a really cool-looking boat hull though!
[QUOTE=DR;8656877]Hi Dave,
Cheers,
Dave
Hi Dave
I have seen ads for that boat ( for something like 400,000 ???) claiming 70 mph but I have a hard time believing they are getting that from an s4 engine and jet drive in such a big boat. Thanks to Mark Anderson, I have every marine part shown in that engine picture. The entire factory "marine kit" weighs a ton. I am going to shelve the closed loop cooling system and water cooled exhaust manifolds for this build.
The main parts I will be using is the special bell housing and a plate that bolts the flywheel to all of the jet drive coupling parts I made.
I will certainly take you up on your offer of tech help First question is do we think the bouncing a boat takes will cause a problem with the air intake plate in the CIS injection system????
Cheers,
Dave
Hi Dave
For those who haven't seen it, I'll post a pic of the engine.
Very nice!
I am assuming your intake is made to hold the stock air cleaner...
That's awesome that you already have the boat kit stuff to
mount it to the jet drive. So other than the engine mounts,
and hooking stuff up, it shouldn't be a super-huge project
to get the engine in there! Look forward to seeing it out
on the water!
on the water!
Are you going to put a huge spacer on the oil pan and pickup and run twice as much oil? I think that's what that other 928 TT boat engine had, probably for good reason.
Dan
'91 928GT S/C 475hp/460lb.ft
Dan
Craic Head
Tass,
Not sure if there are different rules about boats for freshwater use or whatever you plan to do with it, but in my neck of the woods, a marine engine must have a USCG approved air filter setup which includes a USCG stamped flame arrester. (This page includes info on it, among other USCG requirements.
It's for backfire prevention, mostly because of the potential for a backfire igniting fumes in the bilge, especially after fueling up. (Happens every year or two around here when some genius refuels without the bilge fan on. They refuel, hit the key and BOOM! Smoking hole in the water).
Rennlist Sponsor
So yeah, you should do some sort of rubber mounted supports for the "offshore airbox"...I would do front and rear supports from the corners of the airbox if it were me.
OH, and dump the factory air filter for a K&N type 928 Filter, it will hold up better with all the moisture.
Cheers,
Dave
Tass,
Here is a picture of what we are shooting for...........................
I'm pretty sure the stock pan will not hit the floor but I don't know if I have room to make it deeper. Test fitting will give me the answers. I can also modify the pan to be full depth all the way back.....I have no steering or crossmember in the way.
Thanks for the input...I think this is a very good idea and worth pursuing.
