Pod has lost tach, speedo, computer and all instruments except electrical system volt
Had my carpets replaced in my 1993 GTS and now don't have power to the pod - no tach, speedo, oil pressure, computer. I also lost the interior lights but have radio rear lid switch.. It seems like a ground must have become dislodged in the tear out or install. Any suggestions on how to trouble shoot?
By the way the new (July 2011) Hemmings has a cover story on the 928!
All the best!
All the best!
Thanks for the fast reply! the car is at the upholstery shop so I have to relay the instructions remotely as I am on a trip away from home.
(If you're feeling hot an jerkey why not go to Albuquerque!) New Mexico Institute of Mining and Technology 1974
Tell the carpet fitters to replace the fuse they burnt out by shorting the door lamp wires to ground. That will also bring back up the cluster gages. The backside of the passenger footwell cover provides a listing of the fuse locations by function.
Rennlist Sponsor
All the best!
All the best!
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
David Roberts
www.928gt.com
Hi All:
It looks like something other than the fuses (#25 or #10) ...most likely the ground(s)......I hope! I will check tomorrow and will post results.
Thanks you all for your suggestions!
Pod now powered up!
Hi All:
It was fuses 10 and 25 after all despite installer's insistence that the problem was elsewhere. The carpet guy is very good at installing upholstery but not very good at fixing things electrical. I now have a functioning pod, interior lights and an awesome new interior!
Thanks to all for your help!!
Team Owner
tell the carpet shop to plug back in the 2 connectors under the dead pedal they are for the info management system, one is yellow and one is black
if they are removed then the dash will be silent except for the voltage light and the fuel and oil pressure gauges will work but nothing else
