Tec-GT install issues, IT RUNS!! Thread updated
Im installing the Tec-GT ECM
The instructions tell me to connect
The light green (fuel pump relay ground) according to the Tec CD
Carls manual say
Fuel pump and engine power supply wire
a. the light green gets spliced with a diode and connected to the (brown/red W15)
and also gets connected to the (Brown/white W21)
The problem is the diode did not get shipped with it and when I look at the wiring diag. something is not making sense.
I am trying to work around not having the diode
Any Ideas
Carls manual say
Any Ideas
K . . .ILL try
I got a link of the PDF.
Its sheet 10 the relays are at the bottom
http://www.cannell.co.uk/928_Worksho...%20Diagram.pdf
Fuel is in it and this is all thats left before I hook up the bat.
opps I lied, I have to take the rear spacers off and mount the rotors and your new to me wheels
I am trying to figure out why the LH relay xxv is even used except maybe for the shift valve.
Could the diode be required to eliminate the possibility of a spike back to the ECM when switched off.
DEPENDING on the diode, diodes can serve two main purposes.
1: Flow of current can only go one way. So yes, it could stop a reverse voltage spike.
2: A diode can be used to limit the voltage. Example would be 14 volt source, but only 8 volts are needed.
These examples are generic. I have no idea what the diode you need is supposed to do.
I suggest that you email or call Carl to find out what it does.
You need to call him anyway so he can send you the missing diode.
Power and zener diodes to name but a few.
Id be on the phone with the supplier also......I'll do some more reading l8r Brad to attempt assist
I decided to do some live test.
The Green wire from the ECM supplies 12 volts with key on but did not turn off.
The directions were to use power from relay XX11 which was called the LH relay.
This is wrong according to my schematic, the LH is XXV, correct?
