1981 Black Auto
1981 Black Auto
Well I have asked about the car and feel comfortable that its a solid project.
Here is what I'm told about the car.
Picked up the car the receipts show
Analog clock
Phone Dials
Cam shaft o rings
New injectors
New Engine wiring harness 928 MS
Recent TB/WP (Will need to check it out.)
New Borla Cat Back Stainless exhaust. car sounds great when running.
Transmission shifts fine.
New trans cable
New Eibachs
new alternator
Slotted Rotors
new alt cooling hose - not installed need to get one Alternator is suspect now. Called the seller and asked that sionce he had reciepts for new items did he have them.
He said the alternator was new, and he thought the hose was another
New interstate battery that bead
Interior almost perfect.
Need front seats
Complete tool kit
Roof liner install
Gauge cluster has issues
Needs Rubber all around
Sun roof leaks doesn't work missing motor and needs seal kit
Window switches -working now
PS leak - looks like pump needs rebuild
Paint
lots of covered spots.some areas are dull. looks good at 15 feet.
Cold start
PO says car Won't start when cold unless fuel is sprayed into he intake. and battery is bad even though it is less than a year old. I'm told when warm starts fine.
Analog clock
Phone Dials
Cam shaft o rings
New injectors
New trans cable
New Eibachs
new alternator
Slotted Rotors
Need front seats
Complete tool kit
Roof liner install
Paint
Cold start
Phone Dials
New injectors
Other work with total of 4000 + dollars
Needs roof liner install
Wont start when cold unless fuel is sprayed into he intake. I'm told when warm starts fine. Cluster doesn't work
Phone Dials
New injectors
Mine are rescues with all the warts.
James is in a league of his own.
Well, Rod has a few, too.
Hope you took notes during timing belt school Charles.
