Running my Car (S3) on E85 (UPDATE - 7/6 PASSED!)
#31
I've been running ethanol for well over ten years. I have ran e85 for at minimum of 5 years on 944's. There has only been one ill effect that could be remotely associated and that was a fuel pump leaking. However, it was an old unit.
If you really want to get good fuel mileage out of the fuel you may want to think about a low load lean burn. I run around 40 degrees timing and between 16:1-18:1 afrs.
#32
I have been running E85 in a BMW car for about seven years. I have had no problems except the fuel pump stopped working a few years ago. The pump was old so I do not see it as E85 related. Bosch say it should be no problem pumping ethanol using their fuel pumps. The fuel pressure is increased from 2,5 bar to 4,5 bar. Same injectors. It is running a little lean, it is running better on E75 which we have during winter time. E75 will make the engine start easier at cold conditions. Cannot see any rubber parts being detoriated nor any corrosion from water in the fuel. In order to get the power up, the ignition had to be advanced quite a bit. I am now running 43 degrees advanced. This seem to be significant for a E85 conversion.
Ake
Ake
I am surprised by your comments on the bosch pumps, as I was under the impression that these in-line pumps immerse the windings (copper) IN the fuel. That, I understand, was going to be risky with ethanol.
#33
that is correct. I do not use the o2 input on my car though, so that may pose a problem for you unless you have the ability to set specific parameters in your ECU. Other wise it will constantly be pulled back to stoich. I'm not at all familiar with the 928's.
#34
Thanks for contributing. I think I am running quite lean right now, and may up the fuel pressure as well, though with the 02 loop connected, it will still attempt to get to stoich.
#37
Hmmm. I'll have to research that some more. My number still passed, but they were higher than I expected, even with no cat. Cat is going on today for passing grade and getting the car registered properly.
#38
This is simply a "Does it work in a 928 longer term" thread.
#39
Ah. Ethanol is supposed to keep the combustion process much cooler - part of the reason its able to withstand so much cylinder pressure and timing advance. I do recall now that NO is a function of combustion temps.
#40
Yes, unfortunately, higher temps increase the nox, thats what EGR systems are supposed to help with. Screws up everything else, but helps with nox. I don't believe the 928 ever had EGR, but running ethanol without any other changes should result in lower temps, as Brendan suspected.
#41
#42
#43
Man of many SIGs
Brendan,
I just found and purchased some Bosch 36lb low impedence hose barb style injectors today for my E85 turbo project.
By the way, that piece of 928 fuel tank I've had soaking in a mason jar of E85 since 12-26-10 is still perfect in every noticable way.
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
#44
Hey Fabio -
Be careful on the size of the injectors and fuel pressures if you have to have the car smoged - I am going through a steep learning curve right now with the e85 and about stuff I thought I already knew.
First, I want to thank NeilH who came through in the clutch for getting me an air-box top which the ****-like smog individual where I have the retest refused to even retest the car without. That hurdle overcome....
I still failed the test today - even though I put the cats on. Very good shape cats are on the car as of today and I have VERY VERY low HC and NO numbers, but EVEN HIGHER CO numbers now.
This is on NEW 24lb injectors, and higher-than-stock fuel pressure, which I have had to raise in an attempt to cure a (what I now believe is a different) problem with being lean on transition between 2-3k.
But the 15mph test, which he does at 1800 rpm failed the car with very high CO. The 02 sensor loop SHOULD be correcting that richness at that load, but it is obviously NOT or unable to because of the minimum duty cycle on the injectors with my higher fuel pressure.
What I will do is reduce the Fuel pressure to below stock, and then go back and retest.
What I know from this now is that its nearly impossible to run E85 on a stock older car and get what you need out of it without an aftermarket ECU or a complete retune. You cannot, from what I can see, do this on the stock ECU since you would need to do it with fuel pressures and injector sizes (which amounts to rejetting a carb blind)
You need a specific, measurable, and repeatable way of changing the tune to suit the very wide range of usability with E85, and the stock systems simply cannot do it. You need lean idle, very rich transitions, normal cruising, and fat pig rich acell. And the timing needs to be drastically changed to suit the operating parameters. How could the car be operating so poorly and seemingly lean on transition and below 3k, but on this test its pig rich at low speed, near idle, cruise?
Wish me luck.
Wish me luck.
#45
Brendan, glad to help with the air box cover, but sorry to hear the smog results.
if you recall that 84 Auto euro i did the refurb on also failed smog, several times - CO was way to high - and so was NOx. i had new cats installed ( the ones on the car were punched out!) , loaded it with lowest octane I could find and took it for a hard drive in 2nd, got those babies real hot, went to test. CO passed fine, NOx was still way out and it failed again. Not sure what this tells you - but I did eventually ship the car out of state to my daughter - where they don't have a smog test!
Good luck - let me know if I can help you further....
