Pan Gasket - torque specs?
For the Kraken: Steering rack being replaced = motor mounts being replaced, too = pan gasket while we're at it.
Read a lot of pan gasket threads, and they all say to not overtighten the bolts. Well, yeah! But, none of them provides a torque spec, either. Anyone have that info? "Hand tight" is not torque spec.
![order](https://rennlist.com/forums/graemlins/order.gif)
OPG or cork?
For OPG, I go hand snug, by feel, sequentially, trying to equally compress the gasket slightly, with loctite in clean holes.
Not a place where a torque wrench value worked for me. Can't get to some of them anyway.
Snug or hand tight.
wasn't it like 7 ft/lbs
I first hand tighten all bolts, then do a round with 6ft/lb then a round with 7ft/lb. Works for me.
On the hard to get at bolts I use a crowsfoot at the end of the torque wrench.
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
Rennlist Site Sponsor
Crowsfoot on a torque wrench does not give an accurate reading, unless you can get the centerline of the fastener exactly in line with the centerline of the torque wrench - which is really difficult to do.
The WSM has the specs. Give it lots of time between passes. I came back 24 hours later and found the torque values where no where near where I set them. Also make sure you get the shorter fastners in the holes that require them.
