928 Forum 1978-1995
Sponsored by: 928 Specialists
Dans 86.5 refresh project
Old 06-02-2011, 02:54 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,434 Likes on 1,365 Posts
ISV had notches in it indicating a burned armature,
Note the brushes wear grooves into them and then it will stick in a certain position,
The TPS had a lot of oil in it so I replaced it.
Old 06-02-2011, 03:02 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Pictures.
front bumper with new shocks .
Silicone oil pan gasket .
Timing belt run checked, tensioner bushings and pivot bolt replaced as the belt was running a close to flush on the right cam pulley now its back to about 2 MMs from the front edge.
New Volvo MMs installed.
NOTE pan is flush with the cross member,
Washer tank cleaned out, Y connector fitted .
New hood pad being replaced I used Aerokroil it works but the PB blaster works better to remove the adhesive, scrape off the old foam spray down with solvent wait for 30 mins scrape off adhesive then degrease the hood, in this case i removed the hood to make AC work easier but it can be done on the car
Old 06-02-2011, 03:29 PM
chrisdaniel1
chrisdaniel1's Avatar
That is truly beautiful. I'm amazed that's the same car.
Old 06-02-2011, 04:47 PM
cold_beer839
cold_beer839's Avatar
MM,
I really like to see your project threads develop. Under your careful hand that 928 will be excellent again.
Old 06-02-2011, 10:58 PM
BigAl1
BigAl1's Avatar
Awsome work! Love to see how a pro does it - keep the updates coming!
Old 06-03-2011, 11:45 AM
dcrasta
dcrasta's Avatar
Wow you're work is inspiring. Please keep this updated with pics if you can.
Good save another 86.5 stays on the road!
Old 06-03-2011, 07:00 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
time to kick it up a notch,
Honey theres new carpet on the kitchen floor,
got the carpet set from Rob Budd, 27 pieces to install,
BTW He makes this carpet kit, sewing up all the pieces using Sliverknit carpet
one front shock in, (oops sorry its twised 90 deg.)
waiting for a new dust cover part for the other side
Old 06-04-2011, 12:33 PM
fbarnhill
fbarnhill's Avatar
Hey, that carpet set is truely beautiful. How do we get in touch with him? Also, I don't suppose you would consider documenting doing the AC seals? I could never figure out how to do the rexpansion valve on the 79. It is sold now and I also have an 86.5 and will be going through the engine. At the same time, I want to do all the ac stuff that you are doing now. Man, I would truly love to have some pics of which things need replacing. I will have the engine out for several days and I want it to look good for the next few years after it goes back together...
Thanks again for keeping us posted,
Frank
Old 06-04-2011, 01:47 PM
DonT
DonT's Avatar
Mr Merlin - rotated the photo 90 degrees left. (hope you don't mind)
Old 06-04-2011, 02:11 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
For some reason the cosmoline on this car is like epoxy i have cleaned many undersides of 928s and this car has the hardest cosmo to remove ,
it seems like it got a double dose of cosmo it is everywhere.
Frank the Ac system is basically undo the hose connections clean the ends then replace the old O rings with new green ones,
also flush out the components and lines separate so the flush liquid doesnt ruin the new O rings.
This car is going back with freon and mineral oil for the compressor, new expansion valve and drier, new O rings on the compressor manifold,
and possibly compressor lines though they look like they are in good condition.
I got my AC O ring kit from Carquest its about 11.00 hass all the O rings you could need part # MT 2520
Old 06-04-2011, 04:21 PM
UncleMaz
UncleMaz's Avatar
As I am about to tackle the intake refresh portion of this 85/86 refresh, this is a nice complimentary thread to this already fantastic thread. Mrmerlin is in it too: https://rennlist.com/forums/928-foru...pressions.html
Old 06-05-2011, 01:58 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
got the top end back together and did a few parts of the interior,
i like to color combo,
its a lot of work to swap out carpet,
also replaced the expansion valve and the O rings at fuel cooler
Old 06-21-2011, 09:25 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
More work completed,
Pulled out a remarkable amount of wires from the remains of the K 40 radar and the Alpine car alarm and the old stereo, the console is a bit buggered up but it can be fixed needs a clock and ashtray and the console insert where they fit,
I got the engine back together and running time to swap out the Chips,
pulled out the old carpet and started installation, doors are last
got another set of Cup wheels to replace the BBS blues..
Got a new battery from Carquest a free swap out,
as the other battery wouldnt hold a charge
Old 06-22-2011, 12:36 PM
Shane
Sharkaholic
Shane's Avatar
Nice work Stan! Keep the pics coming
Old 06-22-2011, 01:18 PM
Jadz928
Jadz928's Avatar
You're a fricken 928 dynamo!
Quick Reply: Dans 86.5 refresh project
