Noisy Lifters
Even if they were in place and good then. They may not be now.
The 86 cars like mike frye do not suffer from this. Nor do cars with my cams.
I haven't seen an actually hydraulically dead lifter in a 928. Even with 230k miles mine were still perfect. I had one cap that popped out and the lifter noise would come and go ever so slightly. I put in the new cams and reused the lifters for testing purposes. Since then not one lick of lifter noise.
Might want to pop off the covers and inspect. Or just pop off the rear plugs and stick your finger in there. You can feel if it is there or not. And if one is missing you know which cam cover to pull off.
Here is also something to check, I know some recommend it but I would not put Trany fluid in a gasoline eng, I would use a good eng cleaner like the Rosoline(spl) product someone else mentioned.
There is an oil check valve in each head on MYs '87 and up, the manual (page 17 -10) recommends cleaning them if the lifters make noise (on start up).
I'm wondering if my TBF 89 has stuck lifters. The engine I put in had been sitting for a year or two and I'm hearing a noise from the passenger side head, sortof a rattle. I know the air pump makes noise because I spun it with a drill when the engine was out, but this noise is further back from the air pump. I picked up a quart of MMO today and will try that out.
My car is always "clicky" upon cold start. Once it's warm it goes away and stays away. I figure injector noise mainly until it's completely warm.
Its in but hasn't made much difference if any but will take it for a longer run tomorrow (if the weather co=operates) so the oil temp is at full operating level.
Colin, I'm hopeful this works as I dont want to waste anymore of the driving season with downtime.
Minutes or more of normal driving at working temperature if it's a stuck lifter it will work other than you'll have to pull things apart when you get time.
Hope it works for you.
best H
best H
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
will see what tomorrow brings.
Are 16V lifters different from 32V units? Cant recall hearing about noisy lifters in a 16V so far. I run mine on 5W40 Delvac, never hear a thing, even after weeks of standing.
jp 83 Euro S AT 53k
jp 83 Euro S AT 53k
Under the Lift
Under the Lift
