MY86 - what are these?
1) round hockey puck size ceramic disc on side panel adjacent to the a/c accumulator. looks like it has red/yellow wires.
2) adjacent to the jump post, a green wire, terminated in a push on connector.
Pic to follow, if it ever gets uploaded from my phone!
You need to buy a camera
IIRC its the resistor bank for the fan.
Several sensors can trigger the electric fan.
If the intake sensor is the trigger, which would occur with ignition off and the intake heating up as car sits after a run, then the signal is sent through the resistor to run the fans at reduced speed. Diagram shows it if you really dig
-----just coming up to date from my 81, 84 :-)
Inventor
