928 Forum 1978-1995
Sponsored by: 928 Specialists
Help needed with electrical issue - relay 191??
Old Apr 15, 2011 | 08:42 PM
Murray's Avatar
Murray
Unhappy Help needed with electrical issue - relay 191??
I started the car today and the dash instruments didn't were dead and the kickdown wasn't working. There was a buzzing coming from the fuse panel that would stop when the turn signal was on.
When I got it home, I opened the fuse panel and found which relay was making the noise. It is the one marked as "191" in the attached photo. What does this relay do and how difficult to get a replacement?
Any advice is greatly appreciated.
Murray
File Type: jpg
Old Apr 15, 2011 | 08:59 PM
BSnyder's Avatar
BSnyder
http://www.928gt.com/Default1.htm
Hope this helps.
Old Apr 15, 2011 | 09:06 PM
ROG100's Avatar
ROG100
Basic Sponsor
Flasher relay 1HO 953 227 we sell for $7.95.
Old Apr 15, 2011 | 09:12 PM
Murray's Avatar
Murray
Why if that is acting up does it affect the kickdown switch and the instrument cluster??
Old Apr 15, 2011 | 09:30 PM
Bill Ball's Avatar
Bill Ball
Under the Lift
Look at fuse 10. If your interior lights are out as well, look at fuse 24. If they blow on replacement, pull the overhead light down and check it for shorting against the body.
Old Apr 16, 2011 | 01:41 AM
Murray's Avatar
Murray
Thanks Bill.You were right fuse 10 was blown. I replaced that and I took the relay out and cleaned the contacts, took it apart and looked at it. Seemed ok. I gave it a spray of compressed air anyway in case there was some dirt in it somewhere. Put it back in and things were fine. Removed the remnants of an old car phone installation while I had the fuse panel open.
I'll probably end up ordering a replacement relay as a spare and after reading Dean's post I think I'll check to see if my battery is getting a bit weak.
But for now all is good and always thanks for the quick replies everyone.
Murray
