Repairs and changes you have to do before SITM 2011.
Rest in Peace
What is on your list?
And what are the chances they will get done on a percentage scale.
Here is my short list.
Rebuild my G28/10 2:73 LSD trans 25% chance of it getting done.
Install sharkwoofer 95% chance of it getting done.
Install carputer
Install new window switches
install Innovate wideband O2 sensor
Install Sharktuner
this is for the four above, maybe a 20% chance of it getting done, I really hope to have a working Carputer, Hans is trying to work himself to death in getting it all done.
Install new LH unit.
That one is getting done, 100%
Remove hood and front bumper cover for a repaint. 10%
Timing belt replacement. 100% chance
Install shocks and springs
alignment.
This depends on if I can get the parts.
Have new rear tires put on, got to be done soon, so this will happen.
Tighten up right reaar view mirror, maybe a 20% chance.
Have flywheel and clutch balanced, this one should be getting done tomorrow.
Plus, I have three 928's that have to also get finished very soon, big jobs on all three. 100% on these.
Install carputer
Install Sharktuner
alignment.
TB, WP with PorKensioner, check end play, install PKlamp, X-Pipe, high flow cats, replace in tank fuel pump, 33 brake bias, bleed brakes, PSD flush, adjust ride height & align, install new splash guards front & rear, install refurbished front & rear headliners and wire the drop down vanities, install boyo license plate back up camera and tie in with head unit, hardwire GPS unit, finish buff new paint, tint windows, clear bra nose, mirrors, etc, raamat inside rear quarters, LED lights throughout with flasher relays, install pre 85 rear hatch and wire in strip of LED' for 3rd brake light, pack for trip. T
From: In the boatyard installing the mast and engine, we don't need a crane, we harness the mesquito's! Yeah!
Install new mast x 2, paint the topsides, cabin, deck, and bottom... finish engine rebuild and install - install new Genset... and hopefully be out of the yard before June
The 928? JUST DRIVE! Yee Ha!
This will be my last year in the states and I'd love to make it up for the last time to PARTY!!!!!!!!
TB/WP 100%
Instlall Kuhn air/oil seperator, seal coolant brige, coolant flush 100%
Rear brakes/e-brake shoes/rotors/33 bar bias valve - 100%
Rear Ott drop-links 100%
Finished GT exhaust install 100%
R&R CV's 100%
Pod gage LED's 75%
Driver seat memory 75%
HVAC system R&R, new compressor 50%
Pass seat recline 25%
So far, charting well. Have tear down done on the major jobs (less AC comp.)
Next weekend will be cleaning.
A couple following weekends putting back together.
R&R CV's 100%
Pod gage LED's 75%
Rest in Peace
We were also trying to figure out who's going to get the worst gas mileage.
- Check TB tension (regardless of mileage since install) - 100%
- Replace windshield seals and clips - 40%
- Replace door check straps, door lock cyl seals, retint door windows - 30%
- Clean wheel wells - 25%
Got to get all the low percentage stuff done by the end of July for Porsche Parade though. No idea if I even have a chance in the preservation class... gotta get the stock wheels back on for it though - they're at a wheel shop now getting curb rash repaired/refinished. Not sure what I was thinkin' signing up for the councours.
Rest in Peace
Your car and Rogers will be to well tuned to take that prize, unless you are the only two going.
