Spanner Wrenches for Oil Line Fittings
Under the Lift
Bill
Thanx for posting this. I will be looking for a set of these.
I was able to use this cresent wrench from Sears for removal of my oil sender. the jaws are narrow and fit perfectly on the sender.
They open to a maximum of 28mm.
For the oil pressure sender, I had to slightly grind down my crow's foot wrench to make it fit. That said, I would never even attempt to take that thing out without a crow's foot, it makes it so easy.
Dan
'91 928GT S/C
475hp/460lb.ft
Dan
'91 928GT S/C
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
If possible I always try to use tools which grip nuts from more than two sides. It limits possibility of slippage. These are available up to 32mm at least and can be used in most hose and pipe locations in 928.
![](http://kauppa.motonet.fi/images/app/7/big/765119.jpg)
