928 Forum 1978-1995
Sponsored by: 928 Specialists
Windshield Washer System
Old Mar 23, 2011 | 03:38 PM
Landseer's Avatar
Landseer
This write-up is disjointed, but there are some illustrative pictures. Hint: don't overlook the rust sources. Must eliminate them, or it will clog again.
https://rennlist.com/forums/928-foru...mp-repair.html
Old Mar 23, 2011 | 06:11 PM
risaac928's Avatar
risaac928
Thanks for the link and posting those pictures....I will get to work when I get home. Which wont be until 6pm CST....
By the way, where does that fat tube end up going to....
Old Mar 23, 2011 | 11:01 PM
risaac928's Avatar
risaac928
Okay...that fat tube....just as Mr. Merline said it goes directly to the front of the car....The tube runs right underneath the wheel well underneath through the headlight to the washer fluid reservoir on the front of the car...
I tried to blow air through that dam tube and nada...I could not get any air through. I tried to run some water but nope nothing on the other end or any back wash.
Still trying to see if I can get to the end of that dam thing so that I can clear that line. Once I get that fat tube clear of any blockage then I will turn my attention to those washer pumps.
Old Mar 24, 2011 | 12:26 AM
risaac928's Avatar
risaac928
Old Mar 24, 2011 | 12:52 AM
Mrmerlin's Avatar
Mrmerlin
Team Owner
for anyone playing along here,
the washer nozzels for the headlamps have valves in them that will only open or allow fluid past them when a certain pressure is reached,
thus simply blowing through them wont work,
compressed air is needed,
I suggest to use no more than 40 PSI,
if you blow the hose off then you may have to pull the PU cover to install it
Old Mar 24, 2011 | 01:15 AM
Landseer's Avatar
Landseer
There is a valve that sits on the aluminum bumper near the passenger side with one feed, splitting into two outlet streams. Kind of like a little pressure regulator. Can get pretty well gunked up. I thought the individual washer nozzles weren't valved, but might be wrong.
I don't think its accessible without bumper cover removal
Old Mar 24, 2011 | 03:16 PM
risaac928's Avatar
risaac928
Thanks Team....today after work I plan on passing air through that fat tube....
After that going to test those pumps to be sure they work....I will have some video and pictures posted later tonight after I do some the maintenance and trouble shooting..
Old Mar 24, 2011 | 04:38 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
put towels over the squirters so you dont get doused
Old Mar 26, 2011 | 04:39 PM
risaac928's Avatar
risaac928
Okay guys I tested my pump and it WORKS!!!!! But I am not getting any power to it from the car....
http://www.youtube.com/watch?v=Fcltz8ujfsI
Old Mar 26, 2011 | 04:42 PM
risaac928's Avatar
risaac928
Okay...guys here I am trying to get the pump to work with power directly from the car...no power from the car....the fuses are good...
http://www.youtube.com/watch?v=oenNF2ExEM0
Old Mar 26, 2011 | 05:29 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
check your E mail
This pump is for the head lamps
Note this pump wont run till the headlamps are on and the fuse 20 is good and the headlamp washer relay is good
Old Mar 26, 2011 | 08:20 PM
risaac928's Avatar
risaac928
Thanks Mr. Merlin.....here is the front pump....the one in the engine bay sounds just like this one...
http://www.youtube.com/watch?v=jphr3S7TlhM
Old Mar 27, 2011 | 12:07 PM
risaac928's Avatar
risaac928
Ok...got the pump dismantled and as expected these gears are locked up. Going to use some WD40 to loosen those gears and try to get this thing working again....
http://www.youtube.com/watch?v=9ANXTVNf018
Old Mar 27, 2011 | 12:53 PM
risaac928's Avatar
risaac928
Well I cleaned those gears...but still tough to turn. I can get the top gear to turn freely with out any issues, but that bottom one is stiff. I can turn those gears by hand but it does require a bit of effort. Its the bottom that is not cooperating.
I used some WD40 to loosen things up but need some ideas on how get that bottom gear to loosen up a bit more.
http://www.youtube.com/watch?v=Ny7PgAD4t6g
Old Mar 27, 2011 | 01:16 PM
Landseer's Avatar
Landseer
Good video.
I'd clean it up with some 600 sand paper and rinse.
Earring use as tool for car disassembly = 5000 manpoints, irrevocable.
