hood release broken
It's not too bad, and I replaced om RHD car so cable run longer than on yours and required removing carbon canister as it runs behind it on RHS.
Fiddliest bits were at either end. Enters cabin via grommet with bunch of other cables so quite tight. Some grease helped here to push it through.
At hood end I drilled out rivets holding latch receiver then just riveted it back once cable attached.
At the handle you knock out a rivet holding eyelet at end of cable to handle with a punch, then tap it back into the new cable end.
The new cable will operate very smoothly and easily compared with the old.
Before I got round to replacing broken cable I got pretty fast at popping the hood from under car using a long screwdriver and flashlight. It's worryingly easy!
Captain Obvious
Super User
Super User
Then again I do recall moving a thin plastic cover aside where the cooling flaps live, so you could do that with the front tray on?
Team Owner
on cars with well liners remove the liner and the front block off plate then you can see where the cable routes out of the inner fender bulkhead up to the latch,
keep the new cable as straight as possible when routing,
also make sure the latch is lubricated,
and that the height selectors on the bottom of the hood are adjusted correctly ,
and that the latch pin is also adjusted for the correct length.
IE if its too short then the latch will bind and cause the new parts to fail.
NOTE dont add lubricant to the cable it should have a teflon housing any lube may cause the housing to bind/swell after time
