Turbo vs S/C my 928
#61
Ask Anderson about Jean-Louis and his wife Agnes
After the blower was installed 3-4 years ago, his first comment was how much fun it is hanging with and even passing GT3's on the front straight.
This is on a 10.4:1 CR EuroS engine with low 7-8psi of boost. They will be on the track again this Memorial Weekend at Road America.
#62
Administrator - "Tyson"
You simply stated: "Until someone SUCCESSFULLY tracks or does DE events with a blown or supercharged 928......."
Which they have, for more than a few seasons now.
Mentioning DE events I didn't realize your criteria was looking for some kind of overall record
What makes their EuroS even more impressive is they share the car in two different classes. So during a two day DE event the car will go through eight sessions.
#65
Just look at my "race 928 engine life thread"..... Its safe to say Jim has more time on track on his stock 82 engine than many other people....with minimal work too...just like the Estate......
I do think a supercharger is a cost effective way of increasing power for a street car...... but for my $$$ (what little there is) I like NA engines for their reliability!!! 46 hours and counting on a used 117k engine....not to bad for $$$ to time ratio!!!
Flame suit on
#67
It's also important to keep things in perspective. There is no magic dust sprinkled on a new 911TT that somehow makes its performance unattainable by an older 928. Yes, it is much easier to attain good numbers with a PDK-equipped car, but a very good driver with a standard manual (or an automatic, see Tim's G-Tech results above) should be able to do almost the same. Almost since PDK will have slightly faster shifts and has more gears to take advantage of. Just add some more power and traction and/or remove some weight and you will reach the goal. I mean come on, the coupe only has 500hp peak at the crank and weighs just over 3500lbs with PDK. A 500rwhp has almost a 100hp advantage with pretty much the same weight. Oh, and if we were to make it fair turbo - turbo comparison, John Kuhn's setup quite easily makes over 600rwhp; do you seriously think such a 928 would not blow the doors of a 500 crank HP 911? If a 500rwhp 928 on slicks is not getting 0-60 in under 4 seconds, one reason could be that those are not very good slicks...
Dan
'91 928GT S/C 475hp/460lb.ft
Dan
These cars are close to 500 ft lbs of torque at around 2000rpm that is alot of torque down that low so its not just about horespower to get those low et numbers.
The 911 Turbo models generate 500 hp at 6,000 rpm and 480 lb.-ft. of torque between 1,950 rpm and 5,000 rpm
http://www.porsche.com/usa/models/91...turesandspecs/
Pair of slicks on 928 after awhile would be buying axles and other drivetrain parts.
Even the new Corvette ZR1 is faster top end but 0-100 is about .8slower but with slicks would be different story.The all wheel drive pdk and low end torque is what makes the sub 3 second 0-60 numbers on the 911TT.With regular street tires in street trim the 911TT is hard to beat.I'd rather see numbers from the strip than off a G-TECH etc.When it comes to looks thou can't say I like the 911TT better,just like the power.928 today is still a good looking car compared to any Porsche out there.
#69
In Your Face, Ace
Dan
Dan
Somebody show me a real number not generated on a Gtech and I'll drink a glass of kool-aid with ya.
#72
I'd ask to drive the Turbo S 1st to see if its comfortable enough.Drove new Turbo car last year they are nice but alittle more stiff ride I thought compared to 928.Not sure how the ride is on the new Turbo S,best to try it out.A 2011 Turbo S black on black was at the local dealer here it lasted about a week and was sold.
