Thinking of Rear/mid mount turbos.
Some background and info:
http://www.junkyardturbos.com/
1) Pipes to the turbo, past the exhaust housing, and out the back.
2) Pipes from an intake at the turbo, but in clean area, and then up to the intake.
3) Oil lines to the turbo, restrictor, and a pump to return the oil from the turbo to the engine oil pan
4) Blow off valve by intake
6) Wastegate
7) Some way to run engine in boost (https://rennlist.com/forums/928-foru...wesome-11.html or use MSIII (Megasquirt)
Seems sort of simple. In my case, I would run ethanol, so I would forgo the complexities of an inter cooler. No, its not perfect - Perfect is what I am doing on my 78, and that takes a long time. in 2013, that car will be in its 10th year of production.
6) Wastegate
Thanks for the link lots of cool info!
I thought rear turbo's were an urban myth!
I of course, believe that rear mount turbos are just wrong !
The exhaust side of a turbocharger is driven by heat difference across the turbine, by situating the turbo at the rear a lot of that heat (energy) is lost. This is why the exhaust manifold on turbo installations should be as short as possible and lagged or coated to retain energy. Witness the attention to detail on John Kuhns' hot side, indeed his whole installation.
Why not put in a little more effort and build a proper single or twin installation.
My 0.02 cents.
Cheers Roy
My 0.02 cents.
Cheers Roy
I did a mid-mount turbo and am a huge fan of it if you have a 5-speed.
Unfortunately, if you have a Rogerbox you will have to do a rear mount.
After doing the mid mount, I am a huge fan of turbo-ing our cars.
My 0.02 cents.
Cheers Roy
My 0.02 cents.
Cheers Roy
My 0.02 cents.
Cheers Roy
My 0.02 cents.
Cheers Roy
Roy, the fact that the rear/mid mount turbo's WORK is a matter of record here. No argument that closer mounting is better- but its not wrong. It does work, and its a much easier solution for low-boost, bolt-on fun than the twin-turbo setups available.
