928 Forum 1978-1995
Sponsored by: 928 Specialists
Jacking car under steering rack
Old 02-25-2011, 11:33 PM
  #31
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
Originally Posted by linderpat
On those jobs in the engine bay where the cross brace is in the way, the WSM specifically says to remove the cross brace before lifting the car. I nver remove the brace once the wheels are up. It comes off first (or not at all, depending on the job). I think the windshield cracking situations result from removing the brace once the car is up.
Anyone ever documented this?
That would have to be one screwy loose chassis to allow that to happen.
The firewall is the strongest part of the car...its not gonna spread.
Old 03-01-2011, 07:21 PM
  #32
IMGT3
Former Vendor
IMGT3's Avatar
This is a long thread but it points to an alternate approach.
https://rennlist.com/forums/997-gt2-...ackstands.html
Old 03-01-2011, 07:30 PM
  #33
SeanR
SeanR's Avatar
When I'm not using a lift or lift bars (Yes, I use Porkens Lift bars all the time) I will jack up the rear of the car using the cross member. Place jack stands on the jack points.
Then take the jack and center it on the front cross member from behind the front wheels and jack it up until it is just above even with the rear. Place jack stands on the front jack points and then lower the car. Pull the jack out and get to work.
I do not recommend using the rear jack point and lifting the entire car up and placing a jack stand on the front, and repeating that, and then lifing the rear. You lose any stability you had after the first jacking.
These are just my opinions, do with them as you will.
Old 03-02-2011, 12:29 AM
  #34
Erik N
Been selling Twinkies on Ebay,
have some extra cash right now.
Erik N's Avatar
I was at the track the other day and there was a guy w/ a ZO6 who jacked up the whole side of his car from just behind the door. "Wow" I says "So easy!" Yep he says the car is pretty rigid.
Made me want a set of liftbars... and wish there was a central jacking point.
Old 03-02-2011, 01:20 AM
  #35
James Bailey
James Bailey's Avatar
I always lift one side of the old very brown 1980 high enough to change both tires....Do it quite often as I swap wheels for the track. Just use the rear jack point and up it goes. Probably far less stress than it gets running on the track
Quick Reply: Jacking car under steering rack
