Jacking car under steering rack
Well..ya..but MORE...more than what? More than 500FtLbs of torque on a blower? More than hitting a hard bump at 70mph?
The 928 only has as many spot welds as Lotus would use on a good day??
Jacking up by a corner aint never hurt nothing that ive ever heard of...on any car. (Except old Lotus with rotted plywood)
Just for facts I have jacked up the rear driver side and gone to front driver side and put my hand on fender with about 10lbs of pressure and the passenger rear lifts off the ground. I know they are a block of steel. I still am not comfortable jacking as high I like on the factory spots. I do need the lift bars.
Now I am freaked out!
Like Merlin I use the two front areas under the tow hooks.
My jack just barely fits. Once up I use jack stands under each factory point in front, THEN I put roll the jack under the diff
and place stands under the factory points
Am I nuts to do this way?
vanster
80 5sp
vanster
80 5sp
Team Owner
to lift the rear DO NOT jack up the transmission
BUT instead jack up on the lower crossmember use a block of wood between the jack and the cross member
This is a good thread!
I seriously despise using the Porsche jacking method, though have been using for years.
Recently for a quickie lift that doesn't require serious height, I lift on each front corner and place a ramp (reversed, pointed forward), under each front wheel. Then raise the back, the normal method.
I really need to pony up for some liftbars.
I like some of the alternate lifting methods posted here, but you guys either have a low-pro jack or are raising the corners (to unsetlle it), then coming in from the front?
Thomas
just for grins then with the front end off the ground try loosening the engine cross brace, you will see quite a bit of movement of the bolts.
I know there is a bit in the WSM about the windshield cracking if the bar is loosened,
however I have never seen one crack and i usually remove it prior to jacking.
