PET 7.2 on Windows XP
I installed Pet 7.2 on XP Service Pack 2 32bit without any issues, then tried to install it on XP Service Pack 3 32bit and was getting the hardlock error 7 message, after some searching I found a fix here http://files.mytouareg.info/autoinde...TKA_7_Updates/ download the new_aspirin.zip file
extract the files to a folder, double click on VW-AU.exe located in the emulator folder, click on install and start box, then start Pet 7.2. I do not have windows 7 to test it on but its worth a shot.
This sorted it... PERFECT Thanks!!!!!!!!
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
Glad to hear it worked on Vista must be the 32 bit version. So far no fix for Windows 7 64 bit unless you go the virtual machine route.
For anyone that needed a fix for XP. Apparently you have to make sure you install the PET folder in the main C drive. Not in the programs folder. Then you can run the Asprin Emulator and it will work.
If you already installed it then Just copy the folder PET from wherever it is to the main C: Drive and all is good. Finally figured it out after a bunch of testing.
Quote:
"For anyone that needed a fix for XP. Apparently you have to make sure you install the PET folder in the main C drive. Not in the programs folder. Then you can run the Asprin Emulator and it will work."
Thanks, this worked for me.
The new_aspirin.zip file referred to above is gone - anyone still have it?
I'm trying to install PET on a Win XP machine after my garage PC's hard drive died.
