PET 7.2 on Windows XP
Tried running PET 7.2 after installing on Windows XP keep getting: "informations on the used hardlock version of DLL: 1.62." "While addressing the Hardlock, the error 7 occurred." "Ini Station=Lokal". What do I do to get it to run? Does anyone know? Thanks for any help.
1 Post
Hi
As a guess you are running the 64 bit version of XP yes ???
I do not think there is a fix for it as yet, the only way it seems to work without the Hardlock error is in 32 bit Windows...
All the best Brett
Computer came with XP Professional Service Pack 2 installed---I guess it is 64 bit? Don't know much tech stuff about computers--know some tech stuff about my OB. Guess I'll just de-install PET 7.2 or maybe leave installed until and if a fix arises? Thanks again for the help. Best, Greg
Team Owner
I put it on my win 7 and it will not run,
I also am getting the Ini Station=Lokal
any ideas would be appreciated
Stan,
it will not run under win7 64 bit , you will need to download Windows Virtual PC and install that first. That gives you a complete XP 32 bit environment under win7 ( compatibility mode won't work, as there is no way to tell hardlock to run 'as c ompatible).
Once you have loaded virtual pc, start it up, then put in the pet 7.2 disc and let it install.
You can get it, free at
http://www.microsoft.com/windows/virtual-pc/
Good luck,
Good luck,
Stan
Here is a recent thread where this issue was discussed ... which might be helpful for anyone else looking at this thread, who's running another OS.
https://rennlist.com/forums/928-foru...pet-7-2-a.html
Team Owner
still wont run on win 7 with the XP boot up fix , it looks cool though I can see PET in red letters and then a picture of the world
extract the files to a folder, double click on VW-AU.exe located in the emulator folder, click on install and start box, then start Pet 7.2. I do not have windows 7 to test it on but its worth a shot.
Team Owner
I tried to load the PET 7.1 and it also has the hard lock fail also loaded win virtual pc
kinda getting tired of screwing around with all of this nothing is working...
Of course I am not MR computer so it could also be something i missed
The new win 7 program is nice though
Launch it, then put in the pet cd ( won't work from a saved file, must see a cd) install - i have done this now on 4 pc's here, and it works every time, even run son a mac runnig virtual XP pc .
Team Owner
Ahh I think i found my issue i have Win 7 Home Premium and Virtual PC will not support this system it only works in Win 7 professional
