928 Forum 1978-1995
Sponsored by: 928 Specialists
Head gasket surface cleaning
Old Feb 20, 2011 | 10:44 PM
928mac's Avatar
928mac
Default Head gasket surface cleaning
Hello Gentlemen;
Me again with another what's the common practice Question.
So today I got off my seat and went to work cleaning so that I could install at least one of the heads. Didn't happen, still cleaning.
My question is, is it common practice to use a sealer of some type on the block and head to help keep it sealed?
I ask because what ever was left on there was nasty hard, like carbon hard, and some kind of lacer looking or varnish looking coating on the head.
Normally I always put a head gasket on dry and if it would need sealer then maybe it should be machined.
But as I have found out, the 928 is not normal.
So ... what's on the heads besides old gasket?
and
do you guys in the shops put the gaskets on dry, without gasket prep?
Thanks for the time and your much appreciated knowledge.
Old Feb 20, 2011 | 10:52 PM
blown 87's Avatar
blown 87
Rest in Peace
Machine the heads.
Just enough to clean it up on a surface grinder, do not let anybody use a belt on it.
Old Feb 20, 2011 | 10:53 PM
blown 87's Avatar
blown 87
Rest in Peace
Oh, the VR head gaskets go on dry.
Old Feb 20, 2011 | 10:54 PM
AO's Avatar
AO
Supercharged
I used a razor blade held perpendicular to the head and scraped it clean. No risk of gouging the head.
Old Feb 20, 2011 | 11:10 PM
928mac's Avatar
928mac
Well after bout 4 hours this is how it turned out.
I wish there was a head shop in town Greg.
I followed up with a rubber cleaning tool
and a brass wire cone on the drill for the valve chambers
Old Feb 20, 2011 | 11:28 PM
blown 87's Avatar
blown 87
Rest in Peace
I wish there was one also, cause if you used that Roloc pad you are going to need one.
And yes, i know white is for AL, it still should never, ever be used on a head or a block, ever.
Old Feb 21, 2011 | 12:02 AM
928mac's Avatar
928mac
I'm going to find a shop tuesday that has a good reputation for milling heads.
Old Feb 21, 2011 | 01:35 AM
GregBBRD's Avatar
GregBBRD
Former Vendor
Great idea!
Old Feb 21, 2011 | 02:36 PM
928mac's Avatar
928mac
What is the cc of a un-milled stock R3 head.
You can only take so much off and since I do not know this cars history, I should compare where I am at.
Agreed
Old Feb 21, 2011 | 03:04 PM
dr bob's Avatar
dr bob
Chronic Tool Dropper
The WSM gives milling limits, defined as differences in height on a wear pad IIRC.
The operation you are looking for is just the tiniest skim, a thousandth or two at best. This will ensure that the head is flat, and that any small imperfections will disappear enough that the gaskets will seal on the new surface. Those scuff marks from the wheel say that metal was moved around some, but not much beyond the surface scratches at least from the pics you show. Stiil, safest to get it perfectly flat and smooth.
Old Feb 21, 2011 | 03:31 PM
Dennis Wilson's Avatar
Dennis Wilson
Oops, Dr Bob beat me to it.
If the 32 valve heads are like the 16 valves, there are blocks on each end of the head that, when measured and compared to the factory height in the WSM, will tell you how much the head has been previously machined.
Dennis
Old Feb 21, 2011 | 03:35 PM
Speedtoys's Avatar
Speedtoys
The gasket would fizz like soda pop..right?
Old Feb 21, 2011 | 03:38 PM
jeff spahn's Avatar
jeff spahn
Just cause I am stupid I'll ask anyway. Could a scotch brite wheel be used on a dremel?
Old Feb 21, 2011 | 04:24 PM
928mac's Avatar
928mac
The answer would be no Jeff and as explained to me by one of the shop owners is that he had redo some engines that one of his late mechanics used these type of tools on.
The squared edges around the ports gets rounded off and the fluids or pressure wedge past the gaskets causing a leak.
Hence REDO.
Brad
Old Feb 21, 2011 | 07:55 PM
Imo000's Avatar
Imo000
Captain Obvious
Super User
I've used a gasket scraper, not the razor blade type above, and it worked great. Re surfacing is the absolute best solution but cleaning them up well is, to me, another viable option.
