Do I have to buy a new trans? (ruin fill screw with picture)
#32
iirc they did on the later boxes.
22Nm (16ft/lbs) for plugs. As they are a taper plug, and antiseize will make them a bit easier to tighten, go a bit by feel and only tighten as much as is necessary to give a seal and stop them loosening ... even if that's a little bit less.
I don't understand why Porsche went for taper plugs ... especially on the top inspection plug that is opened more often, where they could have used a parallel thread and washer.
#34
Inventor
Makes you wonder what the thinking was behind using taper plugs on gear boxes in the first place.
