Do you replace head bolts every time the head is removed
I think most manufactures say to replace the bolts every time but I thought that I would ask what is normal with you guys.
Are new head bolts required every time you do head gaskets?
Rest in Peace
I replace any head bolt that is a torque to yield bolt, which is almost always one that has a torque plus degrees.
so yes, I replace 928 head bolts, with only Porsche bolts, no aftermarket "super, better" bolts, cause they are neither super or better.
Archive Gatekeeper
Yes, replace 'em.
Archive Gatekeeper
2 things:
2 different lengths of head bolts, 19 mm longer after engine # 81K 05328. You have an '89, make sure you order the right length bolts. (in fact, it would be interesting to list your car's date of manufacture, engine serial #, and whether they're R1 or R2 heads....)
Be careful before signing off on new cam cap bolts, there are 52 (54?) of them and they're $7 or $8 per, IIRC. They're safely reused as long as the heads aren't stripped or rounded.
Rest in Peace
They could be R3 heads, that is what came off my 89.
2 things:
Supercharged
There was a really good thread on this about a year or so ago. Greg Brown measured the torque that results from the 3 90° tightening sequence. And as long as the re-used bolt results in the anticipated torque, you should be good. Obviously if it doesn't, you need a new bolt.
Former Sponsor
Porsche does not insist that the head bolts get replaced after every use...like they do on the rod nuts.
I replace the bolts with fresh bolts on every rebuild/valve job. I am not afraid to torque them and loosen them, if the bolts are new. I believe that they stretch, but are not yielded.
They are sir #928 104 413 3R heads 1 short bolt frt driver and 1 short rear pass
block is a M28/42 81K 07629
Japan vin#WPOZZZ92ZKS842476
$7 e for those cam cap bolts, . . you got to be kidding me, thats 378 bucks
Archive Gatekeeper
Honestly they may be only $4 per, but that's still way too much for reusable bolts.
I have already sent Roger the e-mail and he will let me know.
BTW when the double square strips out I discovered that a #tx 45a Torx socket will tap in and take them out
Former Sponsor
If you give them a good solid hit with a brass drift and use a Hazet socket to remove them, you will not round them out. I've rounded off dozens of Snap-on tools, made for this, over the years. I used to start with one new tool and switch it out, halfway through with a second tool. I'd then give both to my Snap-on dealer and he would replace the "bits". I probably have a half a dozen of these things, in my box.
I finally gave up and only use the Hazet tool. I've used the same one for years and have never worn it out.
Now that's some info I can really use. Thanks Greg.
