The next norcal 928 track weekend!!!!!!
#31
I managed to scrounge together enough funds to register for both the race and open group both days!!!!!! I will be there!!!!!!!!!!!! Time to defend my GT3 time trial win record and hopefully win the GT3 race group too!!!!! I'm excited....it should be another great weekend...hopefully the weather will cooperate!
Everyone else who is interested in going SIGN UP NOW...the lower groups are already FULL on Sat and nearly full on Sunday.....do not wait, this event does sell out...so get your registration in now!!
Your killing me!
March 04, 05
March 11,12,13 SCCA Class
I do want ARC
Same class???
#32
gwen@ncracing.org
Also sign up for the open + race group...3 hours of track time per day including two races......
#33
You will be surprised how well a high mileage tired suspension does in the 928..... You sit pretty low in the car so the sensation of dive-squat-roll is much better than taller cars.... Fresh-ish brakes (I have a stack of old pads for S4's) and a working kickdown is nice...but you can always shift yourself..... works for me
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
The Dunlops I used in Lemons and at the race school work really well.....nice grip for a street tire and last a really long time!!! I plan on using a set of Hoosier R6's that Sean gave me....unless its raining...then I will need the dunlops....otherwise you are welcome to use them!!! I think I still have 6 good ones....
#34
It does make a bit of schedule hassle for you...I'd just leave the trailer at Thunderhill....no sense two long tows in such a short time....I'm sure Coleen would let you store in the yard for cheap....
I am guessing Sean will race in GT2.... So that buts both of us in GT3....which is cool and a bummer at the same time....since your car is faster than mine
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
There is a possibility of "Coach" Kibort getting his trans ready by then too!!!! Hmm a 928 sweep of GT1-2-3...now that would be super cool!!!
#35
Rick
I am guessing Sean will race in GT2.... So that buts both of us in GT3....which is cool and a bummer at the same time....since your car is faster than mine![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
Hopefully I can give you a challenge!!!! While we watch Sean drive off into the distance!!!! My standard "miata" technique of slowing down a bit too much in a corner to force the Miata to lift, so I can power away won't work with you....damm...
Don't underestimate yourself... I had a tough time the last time out keep up with you.
Just trying to get $$ together for all.
and
permission (home)
Any one have a "hall pass"??????
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
#36
I think I will take a fairly long break after this one.....
but it will be FUN...thats for sure
#39
He is optimistic the trans swap will be done by then...... Even if his 928 isn't running he could swing by to help tune in the suspension on the Widow....
#41
Especially on Sunday when we run the bypass!!! I ran 2:06.9 on the bypass!!!
It will be interesting to see how the Hoosiers compare to my old BFG's....
#42
AND..the 1000Hp TT 911 that couldnt quite keep -away- from us...until the RR wheel breaks coming out of 7...likely started to fail in 6a.
http://vimeo.com/19938715
...we'll be back.
#43
Hmm..if I can get my buddy to come down from Reno...He'll get yer car below that. ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
...we'll be back.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
...we'll be back.
#44
The right rim gave out?? looked more like he had massive wheel spin in a very common spot to have wheel spin, and that ran him HARD into the wall. wow, the car became instantly 1 foot narrower. the broken rim was probably from hitting the wall. if it was the left rim, that could be possible.
That was ugly. real bummer!
Remember my race at laguna. Rylan had a broken rim all the way around the center, he lapped around to beat me, only having to run 1 lap, as I was also broke with a disconnected computer (vibration) that I figured out and took off after he broke and was in the pits. pretty hary driving around with a broken center.
If that was Stefanowitz, its about 650 to 700engine HP and all the RSR bits and pieces PLUS a turbo! very very fast. If you are running 1:44 out there, he might be close to being 10 seconds faster. I thin he has run 1:36s out at Sears.
that opening lap, was on pace for about 1:48 FYI off the rolling high speed start.
#45
Hi Sean!!
got the transmission on the floor. drained its oil. its supposed to have come from a 40Kmile S4. LSD looks great. 14ftlbs exactly! (Brian says that is stock spec) so, im ready to go! I mean, here i go trying to install something that ive never done before!
I mean, ive dismantled a few, but never in and out with out a lot of help! (i.e. holbert to donor car transfer at Andersons 928intl shop) ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Now, all I need is a torque tube!
mk
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
mk
