928 Forum 1978-1995
Sponsored by: 928 Specialists
early dyno results
Old 02-15-2011, 04:35 PM
  #166
Tony
Tony's Avatar
Originally Posted by soupcan
Would external oil drain back lines, like this work?
Late to the thread here, but perhaps a less intrusive way to drain the oil would be to modify one of the cam seals at the aft end of each head..the one were the cam does not extend into ?
Tony is offline
Old 02-15-2011, 04:40 PM
  #167
Tony
Tony's Avatar
A slug of oil is suspended in the oil fill hole and forcing the pressure up the head drain holes and pushing oil out cam cover vents, so another way of draining the oil out of the heads is needed and or a new crankcase pressure vent location is needed, correct?
Yes, seems like that is true.
Although i wont see 6000 RPM for those durations, it makes me want to rethink mine. Perhaps the CRANK CASE vent SHOULD NOT be connected to the other two vents on the valve covers. Valve covers would have there own vent...as would the crank shaft/block area...uh..to the atmosphere.
Tony is offline
Old 02-15-2011, 04:59 PM
  #168
killav
killav's Avatar
The black plastic tube aka the oil separator (NLA part number 928 107 731 01) might work during normal driving but probably just gets submerged in oil at high RPM---at which point, acts like a reverse vacume cleaner blowing oil out everywhere. Especially under BOOST.
killav is offline
Old 02-15-2011, 05:08 PM
  #169
AO
Supercharged
AO's Avatar
Why even have a vents on the valve covers?
Just to enrich the discussion, here are a couple of diagrams for the stock setup (32V). S4/GT on the left and GTS on the right.
AO is offline
Old 02-15-2011, 05:11 PM
  #170
GregBBRD
Former Sponsor
GregBBRD's Avatar
Received 2,474 Likes on 1,468 Posts
Originally Posted by Sterling
so would a vacum pump pulling vacum from the lower block help? Do you think that the a dry sump suffer's the same problem? Since the 928 engine runs a higher oil pressure than alot of engines do you think that using the lower volume check valves in the heads as well as pulling vacum on the lower block would help? In looking at my block there were 3 bosses under the intake.. Two for knock sensors and one additional that is plugged.... makes me wonder if I should add a vacum pump on all 3 ports since I'm not using them when I switch over to the ITB setup... I will have more room under the intake....
My first thought was a vacuum pump... I even bought a really nice billet one and started figuring out how to mount it. I got stuck when I started trying to figure out how to deal with the huge volume of oil that would be mixed with the air. It's going to take a pretty big oil separator and then a method of returning the oil from the bottom. The separator will fill very quickly....
GregBBRD is offline
Old 02-15-2011, 05:14 PM
  #171
GregBBRD
Former Sponsor
GregBBRD's Avatar
There is plenty of room, in the heads, to effectively separate the oil from the air, if you vent the crankcase into them...The problem is that this just adds to the oil already trapped up there, once the drains are overwhelmed.
GregBBRD is offline
Old 02-15-2011, 05:15 PM
  #172
GregBBRD
Former Sponsor
GregBBRD's Avatar
Actually, the left is early GTS and the right is late GTS....
GregBBRD is offline
Old 02-15-2011, 05:19 PM
  #173
GregBBRD
Former Sponsor
GregBBRD's Avatar
Exaactly what happens on a stock vehicle. This is why the intake system gets "filled" with oil when the cars are driven aggrressively.
I'm not into the supercharger thing...so I have no idea what happens, under boost.
GregBBRD is offline
Old 02-15-2011, 05:34 PM
  #174
killav
killav's Avatar
My thinking was that X amount of boost translates into more blowby therefore more crankcase pressure to blow the oil out of the stock black plastic tube.
I wish there was a flat type oil separator built into the cam cover that could not possibly get submerged.
We are talking about two problems though. One of them makes a mess, the other fries the bearings.
killav is offline
Old 02-15-2011, 05:50 PM
  #175
928er
928er's Avatar
I think I'm going to replace my cam breather hoses with clear tubing to see what is happening on the dyno......
928er is offline
Old 02-15-2011, 05:53 PM
  #176
soupcan
soupcan's Avatar
I thought I had read here years ago that someone already did that....time to use the search button.
soupcan is offline
Old 02-15-2011, 05:58 PM
  #177
Tony
Tony's Avatar
Proff. Ott has video. Not of the breather tubes but of what goes on under the cam cover.
Tony is offline
Old 02-15-2011, 06:56 PM
  #178
hernanca
hernanca's Avatar
We ran a "928 International" oil deflector plate in the filler neck location. We did not have enough room to run the stock filler neck, so a 5/8" chunk of aluminum was machined down to fit. Into this, we installed an oil filler and vent fitting into the far right hand (1-4 cylinders are right) rear corner. We then attached a -10 hose to this vent fitting and ran it back and up, into the air filter box. Total rise of the vent hose was about 10 inches.
Timely thread!
I have been thinking of upgrading the breathing on the stroker (I bought the one Greg built for Brian Fleming), and have been reading up on breathing options for these motors. Based on what I have learned, I have not liked the idea of allowing any significant flow out of the heads. It just seems to encourage an undesired exit route for the crankcase pressurized "fog", because, for DOHC motors anyway, it would compete with a more significant amount of oil wanting to drain back from the DOHC heads (as opposed to pushrod engines, needing less oil in their heads, and which have those cool breathers on their valve covers).
I'm not a Physics major, nor have Greg's practical experience in this, so I could be pretty far off here.. but plumbing exit routes from the heads to the intake plenum, as I have heard that many folks do or want to do, would just seem to make the problem worse at higher RPM's by providing an even lower pressure, and thus more appealing, exit route, for the pressurized fog. I don't know to what degree, but at the higher RPM's, this would seem to have the same effect as increasing the diameter of that tubing, even if they have restrictors, and there are many more of these tubes coming from the heads than from the crankcase.
Greg, I suspect it is safe to assume that you've done the calculations comparing the total area of the stock openings (crankcase, heads) vs. this set up. To me, just going by the pictures, the stock crankcase vent plate plumbing looks more restrictive than stock, but you also have that custom oil filler (right rear corner) which may provide additional venting to the crankcase.
For the crankcase only, does the total area (of exit openings) of the current set up, exceed the stock set up? My guess would be that it should do so by about 30%.
For my street-only 86.5 based stroker, I am coming up with the following set up:
928 International oil deflector plate in oil filler location
928 Specialists SharkVent system, customized as follows:
* ProVent inlet connected only to the oil filler with Big A&& Hose
* Depending on pressure/vacuum readings: either two one-way (inlet only) filtered breathers on both heads, plumbed to the fenderwells; or just plug the head outlets.
* draft tube connected to ProVent air outlet
* drainable catch can between ProVent outlet and drain back to crankcase (catch can overflow, if any, would drain to crankcase)
hernanca is offline
Old 02-15-2011, 07:03 PM
  #179
Ketchmi
Ketchmi's Avatar
A long time ago I built some air/oil separators that go in the cam covers and installed small K&N filters on the top. I then ran a vacuum from the inlet of the air pump (using a venturi) through another air/oil separator (which drains back into the pan) to the oil fill. This system when properly adjusted pulls air from the crankcase (and oil down the cylinder head drains) using the cam covers as the air inlet. When it's not properly adjusted, it will suck the oil right out of the engine, through the air pump and inject it into the cats. Good for killing mosquitos but not for anything else. Granted, this car is supercharged and with over 600rwhp, doesn't see extended WOT for any extended amount of time but the K&N filters are still pink after several years of use. Very little vapor and no liquid oil comes out of the cam covers.
BTW, I use stainless pot scrubbers in my air/oil separators...any good reason to use copper other than being able to corrode with condensation?
Ketchmi is offline
Old 02-15-2011, 07:11 PM
  #180
andy-gts
andy-gts's Avatar
wouldn't scavenging the crankcase to a negative 8 or 10 psi potentially solve both problems and then dump the suctioned oil vapor from the crankcase into a separator or catch can and this will encourage (through pressure differential) to empty the heads down the respective drainage pathways. All the time giving you the extra 15 hp the dry sump guys from doing this?
andy-gts is offline
Quick Reply: early dyno results
