Rear Bumperette Delete--HOW TO
#31
What I found with the SEM product was that it did not adhere very well to ABS plastic which I was using for the patch material; but where I used it and then simply pulled the ABS material off in the back, what was left was virtually as strong as the base material of the bumper cover. The butt joints that were left seem simply as strong as if there had been no joint to start with.
Plastic is really amazing to work with.
Jerry Feather
#32
Yes, that gun is the normal way Jerry. Do you remember my post about the fact that you don't need the crazy gun and you can just mush it together on a pallet? It almost seems to form together with the original substrate. It worked great, and for custom work like yours I think it would even be better.
#33
Then there is the problem about what to make the new insert out of. Fiberglass would be obvious, then there is the problem of flexibility. I suppose I could even form a new isert out of ABS like some of the other stuff I make, but, again that effort does not seem to me to be worth the effort since we all have what we need to start with.
There are more cuts in what I have done in this thread because I didn't think the project through well enough to start with, so this project can be accomplished with a little less effort than you have all seen here. Not much, but a little.
I don't think there is going to be a kit for this modification from ReDesign by Feather anywhere in the future.
Jerry Feather
#34
I linked this thread to Van's question about deleting his bumperettes, but I haven't considered the differences between the early and late rear bumper covers. I suspect this basic approach can be used with either style.
I'm bumping this thread now because if this cover has not deteriorated too much over time and not having been put on one of my cars, I plan to use it with the Radical Custom 928. I'm going to start the section with it shortly because I think I am going to need the top half of it to bolt to the car to help align the rear of the hatch which is going to be the next phase of the top chop.
