Devek Level 2 Headers Installed! (Video added)
#61
Supercharged
Not quite, but it's still pretty rich upstairs. The other thing is I have the boost-activated switch that immediately dumps fuel in so I don't get any lean tip-in. Plus it was like 39° F outside which richens the mixture up and the car wasn't fully warm. SO yeah... close to 10. Low 11's, upper 10's. It's lower on the list.
#62
Supercharged
Cool. holy cow you got it for under 2K, thats not bad.
I have to say that the X pipe dose look like a bit of a bottle neck.
I don't think it would look like that if the angle of the headers were not so great or if the x was flatter and wider.
Dose the X make that big of a difference compared to duel exhaust with out the X?
Brad
Brad
In other good news, my oil leak was not from the oil cooler. It turns out I either popped the dipstick or didn't insert it all the way. 1 can of brake clean later... all seems to be good. Took it out for a very quick romp last night to see if I popped the dipstick (afterall I have a new breather setup) and it seemed fine. Need to keep an eye on that.
#64
That is so cool and the exhaust looks and sounds great.
I was just wondering if anyone has ever recorded, before and after numbers comparing the X to a simple duel exhaust.
You got a smokin deal on a great system I would have to say.
#66
Its so difficult to determine what an exhaust sounds like from video. It sounds just a BIT more muffled than mine, and its an H-pipe of unknown origin, two late-style small resonators, and nothing else. and you have three mufflers. Wierd.
#67
[QUOTE=AO;8390578]Had to share.
Weather was nice out this evening (finally!) so I decided to record a run from the back bumper. Check out the 0:56 mark!![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
Sweet Andrew! What camera and mount are you using?
#69
Supercharged
[QUOTE=993MI;8390698]
Canon PowerShot SD700 and a suction cup mount. Might have to retry with the wife's new camera that records in 1080 and stereo.
#71
