928 Forum 1978-1995
Sponsored by: 928 Specialists
Devek Level 2 Headers Installed! (Video added)
Old 03-14-2011, 01:47 AM
  #46
IcemanG17
IcemanG17's Avatar
Originally Posted by AO
Video is up. It doesn't do it justice.
NICE...I also like the fire on decel....the Estate does that since we disconnected the L jet idle "cut" to get better throttle response
Old 03-14-2011, 08:54 AM
  #47
RKD in OKC
RKD in OKC's Avatar
Exhaust sounds great. Also that chirp sounds like you need a clutch arm pivot.
Old 03-14-2011, 09:41 AM
  #48
AO
Supercharged
AO's Avatar
Thanks for the props. Yeah it's still running pretty rich at start up. Need to get back in there and do a little ST'ing, but the little flame was cool, wasn't it!
No, the pivot is fine. It's one of the drawbacks of the Spec Stage 3+ clutch. It's kind of hard to slip the clutch because it grabs so hard. So it chirps like that upon take off. No biggie.
Old 03-14-2011, 12:39 PM
  #49
RET
RET's Avatar
Looks and sounds great. Very nice, and very nice work.
How can the passenger side coolant drain plug on the engine block be accessed? This is not merely a random question (...and I hate admitting ignorance, inability, or lack of ingenuity...), but I have not been able to figure out how to do this, short of removing the A/C compressor or the header itself.
Unfortunately, both of those options are more work and likely to create more problems than the benefits are worth, so I have compromised by changing the coolant out more often with the fond hope that I am sufficiently diluting the leftover undesirable stuff.
Also, what will you do about (and/or, what causes) the exhaust flame?
Bob
6 liter '89 GT with Devek L2 headers, X pipe, dual exhaust, Borla mufflers, etc.
Old 03-14-2011, 12:44 PM
  #50
SeanR
SeanR's Avatar
Andrew, that that little header X cost you $500.00?
Old 03-14-2011, 12:58 PM
  #51
77tony
77tony's Avatar
Clean install, and it sure sounds menacing. T
Old 03-14-2011, 01:07 PM
  #52
finally!
finally!'s Avatar
DAYUM! That sounds like pure sex!
Old 03-14-2011, 01:08 PM
  #53
Drewster67
Drewster67's Avatar
Sounds excellent! Time for some hot laps ...
Old 03-14-2011, 01:22 PM
  #54
AO
Supercharged
AO's Avatar
Ohhh... a bit more than that, but not much more. Ok, I'll break the cardinal rule and add up the receipts... so here's the total damage:
Headers: $450.00 (a steal)
Flanges and gaskets to mate up with the headers: $58
Mid-Mufflers: 2 x Magnaflow 14377: $200
Final Muffler: 1 Magnaflow 11379: $100
Stainless Pipe work and installation: $850
Total all in: $1,658.
Not bad. I was expecting it to cost about $2k.
Old 03-14-2011, 06:54 PM
  #55
RKD in OKC
RKD in OKC's Avatar
Are you sure. I was talking about the occasional chirp in the last video with the car sitting still. My GTS was doing that and it was the clutch arm pivot bushing.
Old 03-14-2011, 07:46 PM
  #56
Bill Ball
Under the Lift
Bill Ball's Avatar
Black smoke! What's the AFR like? Looks like <10.
Old 03-14-2011, 07:49 PM
  #57
Mongo
Official Bay Area Patriot
Fuse 24 Assassin
Mongo's Avatar
Do all 928s shoot flames when you take the cats off?
Old 03-14-2011, 08:17 PM
  #58
Jon B.
Jon B.'s Avatar
Yep, totally need some headers.
Old 03-14-2011, 10:07 PM
  #59
928mac
928mac's Avatar
Cool. holy cow you got it for under 2K, thats not bad.
I have to say that the X pipe dose look like a bit of a bottle neck.
I don't think it would look like that if the angle of the headers were not so great or if the x was flatter and wider.
Dose the X make that big of a difference compared to duel exhaust with out the X?
Brad
Old 03-15-2011, 01:43 PM
  #60
AO
Supercharged
AO's Avatar
It doesn't always make that sound. If I get the revs and release just right, it's silent. I replaced the pivot bushing when it I installed the clutch and it's been like that ever since, so I've always chalked it up to the clutch. When I take the clutch out again, I'll take a look. Unfortunately, with the SCer installed, I can't see it from above.
Quick Reply: Devek Level 2 Headers Installed! (Video added)
