928 Forum 1978-1995
Sponsored by: 928 Specialists
Pull engine or not?
Old Feb 18, 2011 | 02:22 AM
  #31
Dave928S's Avatar
Dave928S
Definitely disconnect the bellhousing from the engine to get it out.
It also helps to have a spreader bar attached to the lift points which gives you a lower connection point and the ability to lift the engine higher to clear the body. The spreader also lets you tilt the engine back more easily to clear the firewall, crossmember and body.
Double check you've disconnected everything before you start lifting ... and then check again while you're lifting to see that nothing's hung up or catching.
If you've got a welder you can easily make something like this ....
File Type: jpg
Old Feb 18, 2011 | 08:16 AM
  #32
gbgastowers's Avatar
gbgastowers
Is there any way to attach a cherry picker to the engine that keeps it level instead of cockeyed due to the offset attachment points? By the way, don't use the wood in my picture because it hits the top of the firewall.
File Type: jpg
Old Feb 18, 2011 | 10:09 AM
  #33
GlenL's Avatar
GlenL
Yes. Use a third chain to the left-front of the engine.
Check the pics of the official Porsche engine removal tool. It has three attachment points to the engine. I run a chain to the PS bracket.
Old Feb 18, 2011 | 07:59 PM
  #34
Hkp7's Avatar
Hkp7
Good and bad news here, had drivers side dowel stuck but got it free, engine came out smoothly although I had one problem, the hoist could only get the engine in the air just high enough, the engine put a big scratch on drivers side fender. It was down to the primer. Well, now its time to pull the heads, clean clean clean, and re seal everything. wondering what bolts I should use to attach to engine stand.
Old Feb 19, 2011 | 01:52 AM
  #35
gbgastowers
Pull one of these from passenger and driver side and use them in the top part of the engine stand. They will go in the upper threaded part of your bell housing. You can buy some standard ones for the bottom since there are no threads there. Make sure they are long enough where you can put a nut on the backside.
File Type: jpg
Old Feb 19, 2011 | 06:46 PM
  #36
Hkp7's Avatar
Hkp7
Just started disassmebling engine. The cheapo engine stand from harbor freight is garbage. I left the cherry picker connnected to prevent a fall. the engine tilts forward extremely far. The stand is rated at 750 lbs. I need a better one before moving forward. One of the cam tower bolts is stripped on the drivers side. I was going to either drill off the head or find some type of quality bolt extractor. I removed the head from the passenger side and found no noticable head gasket problems. Kinda stuck at the moment. Need more tools.
Old Feb 19, 2011 | 10:41 PM
  #37
davek9's Avatar
davek9
HF's 2000lb works great, picked one up for $81 bucks on sale, IMHO that one is maxed out, I like to use twice the capacity what I need.
Dave K
File Type: jpg
Old Feb 20, 2011 | 01:04 AM
  #38
soontobered84's Avatar
soontobered84
Glad you pulled the engine. Sorry you put the scratch on your fender.
I had to retighten the bottom front two cam cover bolts on the passenger side. It took me over two hours to tighten those two bolts 1/2 turn each. Will definitely recommend removing the engine.
Old Feb 22, 2011 | 08:50 PM
  #39
Hkp7's Avatar
Hkp7
While taking things apart. Is this piston in the picture supposed to be on an 84 16v U.S.???
File Type: jpg
Old Feb 28, 2011 | 07:54 PM
  #40
Hkp7's Avatar
Hkp7
Here is what I found so far. Three of the lifters seem to depress easily with finger, the rest wont budge. also found two high spots on one of the heads. Didnt look like anything got past but I would like to know what you guys think. Head gaskets had no noticable holes or failures. Also in my previous reply to thread, I found that piston and spring are not present in my engine that are listed in picture. Help would be appreciated.
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old Feb 28, 2011 | 08:05 PM
  #41
namasgt's Avatar
namasgt
Can you post pictures from both sides of the two head gaskets side by side?
Also post pictures of the deck surface of the block.
lifters depressing is normal since oil will bleed out of them when the car sits for a long time. Make sure you don't mix them and they go back to their original location.
Old Feb 28, 2011 | 08:13 PM
  #42
namasgt's Avatar
namasgt
I used the harbor freight one too, but I got the 1000 pound one, see if you can return this one and get the stronger one, put something under the oil pan, like a piece of wood from home depot so the weight doesn't damage the mounting holes on the block.
Also about those piston and spring, if you have them their next to where the oil filter mounts, there's two of them, I'm not sure but I think one of them is for the engine oil cooler.
Old Feb 28, 2011 | 08:17 PM
  #43
Hkp7's Avatar
Hkp7
Here are some more pics.
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old Feb 28, 2011 | 08:32 PM
  #44
namasgt's Avatar
namasgt
The head gaskets look pretty good, the engine looks pretty good too.
Can you please explain again why the engine was pulled?
I see the pic for the coolant in the intake port, but I would think that the chamber would look clean??
Old Feb 28, 2011 | 08:41 PM
  #45
Hkp7's Avatar
Hkp7
I pulled the engine because of a rough running condition under load and then found foamy oil along with coolant on top of an intake valve. I have replaced a lot of parts chasing this problem. Also did a lot of tests that came out good. Compression was good, fuel pressure was good, no major vacuum leaks that I could find. Oil pressure was 120 cold although ive been told this is normal. was suspecting a cracked head and found nothing. At least at this point I can resolve all my oil leaks and clean out the engine bay.
