Rear seat removal and rear seat belt upgrade
Steve,
Great work! When all done do a write up using pics in Word (or whatever you like) and lets get it over to Stan for hosting on the 928 Owners Club site too!
My S4 has the same interior color as yours and I am heartened to see your carpets are as dirty and mismatching to the seats as mine are now days! I think they need to be completely pulled and SERIOUSLY cleaned! Linen is BEAUTIFUL but it is hard to really keep clean...just a few drives with the windows down and you can have it dirty!
Looks like you have the newer rear seat design, so console has to come up to get last bolt out. Earlier cars had a pin that fit into a bushing on the inside hinge, but the design changed. As Stan said in his post, the trick on the console is to pry the four upright metal bars away from the sides of the A/C evaporator box, then just work the whole unit up and off. I used a couple putty knifes and small screwdrivers to open these up so they let go of the evap. box.
Team Owner
OK to remove the console first at the rear of the center vent there are 2 screws remove them, then lift the rear vent up to 45 deg pull back
Then adjacent to where the little fingers went front of the rear vent , are 2 more screws possibly hidden by the console covering material remove these.
Then lift the rear edge of the top cover to 45 degrees then pull back. this removes the top console cover.
Then along the evaporater are 4 fine threaded screws holding the metal bars to the sides remove these only.
Then carefully pull the sides of the console apart as you lift the console upwards,
make sure to have the metal bars clear of the sides of the housing,
once they are clear then the console will lift off.
NOTE there is a metal rib along the rear edge of the console make sure to have this also clear the evap housing
IE lift the front of the console a bit higher and push it rearwards to clear the evap housing
I found a picture of a removed rear seat. Apparently, the second allen bolt at the inner pivot/bracket is hidden by the rear AC console. I have also tried to slide the seat out of the inner pivot as Chris seemed to have indicated but no yield. It does look like it would come out since I did not see any C-clip. But no luck. Looks like I have to take out the AC console as Hilton stated. I have no clue how to do it.
Steve
Steve
Just got back to this after yesterdays post. Yes, you need to remove the seat uppers completely in the later cars (85 onwards I assume - as thats when the front seats changed?).
That means getting to all 4 socket-head bolts, so the center console in the rear has to come out to get the two bolts you've spotted in the photo you included.
After that its very straightforward.
So I need someone to tell me where to find the anchor for the belt. A picture of that would be perfect.
If my 4 year old boy did not like the 928 so much that I would just dump the rear seats and the AC to make it a 2 seater.
Steve
Steve
You'll feel a circular depression about 5/8" diameter. I'll go take a picture - I've got the quarter panels out of my '89 at the moment so it'll be of the actual bolt hole in the frame.
Here it is.. further back than I remembered That's the right-side quarter window.
I cut my rear quarter pillar using a box-cutter with a fresh blade - just poked it in the hole 4 times, from rough center outwards to make a + sign, and then pushed in each triangular tab.
If you don't have them, I recommend ordering the correct bolts, spacer rings, caps etc. from 928intl - the spacer rings are needed to push the metal tab of the belt end away from the quarter panel and allow some rotational movement.
I do want to know if the factory cut the leather hole in a +/cross fashion or a regular circular hole.
Steve
Great write-up. Thanks for the thorough documentation. Does anyone know what model year they started adding the bolt hole for the 3-point belts? Was it always there? I'd like to do this update to my '84 when my girls outgrow baby seats, but not sure if I have the bolt mounting point. When I feel the C-pillar leather covering it does feel like there is a small opening in the right location.
From 1984 onwards, the rear belts all use the same style retractor, so you should be able to fit rear 3-point belts from a late US model to an 84. Earlier than that the retractor body is a different shape so may not fit the later belts.
