Water pump rebuild
There is a guy on e-bay who sells parts to rebuild 928 water pumps. I guess there is some variation in the different pumps used. Has anyone tried this?
It really does not look like too much of a job if you have a good press and some patience. The parts are only $33 which is a huge savings.
Team Owner
SRSLY???
Having access to a new Laso pump I woudnt even consider this.
This isnt a part to experiment with
JMHO
JMHO
Former Sponsor
If you have a "virgin" never been touched Porsche factory pump (one that hasn't been already rebuilt 3-4 times)...you could try it...see post #2.
Rest in Peace
No friggen way would I touch one.
That pump is the weak point in a properly maintained 928 timing belt system, you want the absolute best one you can buy, regardless of costs.
Dan you were away for a while and may have missed some of the latest developments in 928 water pump discussions. Recommended readings:
https://rennlist.com/forums/928-foru...ics-added.html
https://rennlist.com/forums/928-foru...your-bets.html
https://rennlist.com/forums/928-foru...-impeller.html
