928 Forum 1978-1995
Sponsored by: 928 Specialists
Sideways jolt when hitting the Go-pedel
Old 01-12-2011, 04:01 PM
  #31
Ducman82
Ducman82's Avatar
jacked it up and re checked it today... driver rear wheel bearing is trash. no noise. but i can wiggle tire. yay! now i know what it is.
Old 01-12-2011, 05:57 PM
  #32
erwalker
erwalker's Avatar
You may just need to adjust the wheel bearing nut. Both my front bearings were loose on my car and once the adjustment was made, no more play. Not sure how/if the rear bearing can be adjusted but worth looking at if it saves you from having to buy a bearing.
Old 01-12-2011, 08:24 PM
  #33
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,495 Likes on 1,404 Posts
the rear bearings are not adjustable they are fixed , when the axle nut is torqued to 320 ft/lbs
Old 01-12-2011, 08:43 PM
  #34
Ducman82
Ducman82's Avatar
Well i am a F'n moron. go to the junk yard, yank both lower control arms (for later) and both hub assembles, get home, get ready to clean and replace...... (multi-able expletives...) turns out to be a stripped lower control arm/hub nut.... replaced the one little nut, torque.... done. so when i checked and torqued last, the nut was still crap. so it went loose again.... sigh......
Old 01-12-2011, 10:56 PM
  #35
dr bob
Chronic Tool Dropper
dr bob's Avatar
The good news is that you found it. Better news is that it didn't strand you or worse.
Old 01-13-2011, 09:18 AM
  #36
Ducman82
Ducman82's Avatar
indeed. im just shocked that the nut let me torque it last week..... while stripped!
Old 01-13-2011, 11:30 AM
  #37
Mrmerlin
Team Owner
Mrmerlin's Avatar
what nut are you talking about??
the lower shock pin??
or the axle nut?
Lower shock pin nut SB 82 ft/lbs and the axle is 320ft/lb
Old 01-13-2011, 01:35 PM
  #38
Lizard928
Lizard928's Avatar
From reading it, I would say the axle nut.
Old 01-13-2011, 03:47 PM
  #39
Ducman82
Ducman82's Avatar
not the axle nut, but the double ended "pin" that connects the control arm, hub, and shock (think cone washers). one end was stripped. atleast i go a new pin from the junk yard, cleaned it up, torqued to spec. all good :-)
Old 01-13-2011, 04:14 PM
  #40
Mrmerlin
Team Owner
Mrmerlin's Avatar
FWIW, I wasnt the only one confused with the provided info.
Glad you got it sorted out
Old 01-13-2011, 04:20 PM
  #41
Ducman82
Ducman82's Avatar
:-( sorry to confuse anyone....
god i love driving this car....
Old 01-13-2011, 05:09 PM
  #42
atb
atb's Avatar
Man, that guy way back on post #4 almost knew what he was talking about !
(Wally P. give me the same advice when I had the same problem many moons ago).
It is weird to feel the chassis rotate on the suspension like that. Mechanically, I don't understand why the loose nut would cause this kind of action, it's pretty wild. (Please don't try to explain, I'm enjoying the bliss of my mechanical ignorance on this particular point).
Quick Reply: Sideways jolt when hitting the Go-pedel
