Need Help....928 Euro engine
Long black? Short block? Y'all know these definitions vary regionally.
You just need a bare block. They're all the same...except for the piston tolerances. (There had to be an "except" in there.) You will probably need a new crank as well. The block and crank can be from the comparatively un-loved US 4.7 engines. ('83-'84?)
The fine folks at 928 International will set you up. Or check eBay.
