928 Forum 1978-1995
Sponsored by: 928 Specialists
Jack with integrated jack stands
Old 12-07-2010, 02:57 PM
Fabio421
Man of many SIGs
Fabio421's Avatar
Default Jack with integrated jack stands
Check this out. A fellow Rennlister told me about this product years ago and was raving about how great it was. I've never been able to find it until now. It looks like it would be great for the 928 if the quality is there.
http://www.sears.com/shc/s/p_10153_1...00#reviewsWrap
Old 12-07-2010, 03:04 PM
UncleMaz
UncleMaz's Avatar
It needs about 4 more inches of lift to be perfect, but I like the idea.
Old 12-07-2010, 03:05 PM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,206 Likes on 1,245 Posts
It has been listed as "temporarily unavailable" for quite some time on the Sears site.
Have you tried to buy one locally?
Old 12-07-2010, 04:24 PM
karl ruiter
karl ruiter's Avatar
There was a system available a few years back much like this one. It was much more expensive. And I was never sure I wanted to trust my life to those stands. But you could augment with a couple of more rugged stands, I suppose as backup.
Old 12-07-2010, 06:25 PM
tveltman
tveltman's Avatar
This thing has too many moving parts for me. I cant seem to see how it works...
But then again, I may not be the sharpest tool in the shed...
Old 12-07-2010, 06:57 PM
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
The front of the jack, secures the base of the stand.
The top of the stand has that candybar shaped plate that sits over the tip of the jack that goes up, as you jack it.
As the jack stand post goes up, a self slip & lock mechanism allows the jack-stand post to get longer (it has a couple of telescoping sections) in what look like about 1/2" increments. When thats all set, you just collapse the jack portion, and the stand portion stays in place as you pull out the jack itself.
Old 12-07-2010, 07:16 PM
danglerb
danglerb's Avatar
Astro Pneumatic (I think) has combo jack/jack stand, but I suspect the best option for the 928 are the Liftbars and a conventional jack and stands.
Another good alternative is to make an adapter board that fits I think on the front cross member so a conventional jack lifts the whole front end and stands can be placed easily.
Old 12-07-2010, 08:32 PM
fraggle
fraggle's Avatar
That one looks too high to clear under the car for the initial lift. Looks a little narrow, too... I'll stick with my method and the big stands.
Old 12-07-2010, 08:47 PM
jthwan22
jthwan22's Avatar
It would solve the problem of only 1 jack point each corner. Some times the jack and the stand gets in each others' way.
I no longer have this problem since I finish installing the Maxjax lift. Now I need to sell the lift bar.
Old 12-07-2010, 08:54 PM
Speedtoys
Speedtoys's Avatar
Ive considered welding a plate under the car, as a secondary point to place either a jack or a stand...similar to a baseplate for a cage..cept under the car.
Old 12-07-2010, 08:57 PM
UncleMaz
UncleMaz's Avatar
Interesting idea.
Old 12-07-2010, 09:18 PM
karl ruiter
Carl actually sells such plates, shaped to fit the 'frame' rail.
Old 12-07-2010, 09:40 PM
Speedtoys
Speedtoys's Avatar
Who is Carl? Where is Carls www site?
Old 12-07-2010, 11:01 PM
fraggle
fraggle's Avatar
928motorsports.com
I just jack the front using the a-arm mounting points, flop stands in the front right & left jack points (this takes use of the jack 3 times to get it high enough) then go to the back and lift on the crossmember.
Liftbars would be nicer though.
Old 12-08-2010, 12:30 AM
Speedtoys
Speedtoys's Avatar
Link:
http://www.928motorsports.com/parts/...jackpoints.php
And a VERY good price for the work/materials required.
Quick Reply: Jack with integrated jack stands
