928 Forum 1978-1995
Sponsored by: 928 Specialists
S3 cams in an S4
Old 11-28-2010, 10:05 PM
  #31
IcemanG17
IcemanG17's Avatar
Originally Posted by pantera928
387 RWHP! how did he accomplish that? I would love to see 320 RWHP. Stroker? Nitrous?
Not sure what a Hammer or Theo scanner is? Any in the Atlanta area? I assume that they can only get my car up to the original 316 HP? Not miracle machines are they? I feel like the car runs well (looks like crap) but there could always be something going undetected. This is my first S4 and almost all of my experience is with 16 valve cars.
Regarding Polecat, I think he sent me an inquiry a while back about Panteras. Two totally different animals but both fun in their own ways. I sold my first 928 and a vette to get my Pantera.
Its really not as much as you think...custom cams and proper tuning is about it on top of a full race exhaust with headers.....I think Dennis's stock S4 engine was about 300whp....which is typical for stock S4's with race exhaust...all the internals were stock.....
Old 11-28-2010, 11:37 PM
  #32
pantera928
pantera928's Avatar
I usually approximate loss from flywheel to RWHP at about 20%. E.G. a 300HP motor will deliver about 240 RWHP. Do you think that loss is about right?
Old 11-29-2010, 03:03 AM
  #33
mark kibort
mark kibort's Avatar
no, that is not right, but maybe in the case of the automatics.
remember, that number is worst case, generally found in the upper gears at top speed to 50% of that top speed where the rolling losses alone halve in value. 20hp loss at 150mph goind down to 10hp loss at 75mph. for example.
15 % is the max loss you will see.
Old 11-29-2010, 03:07 AM
  #34
mark kibort
I got 335 rwhp a few times, when the motor was fresh-er. only 15 years old at the time.
it was a true 335rwhp. dennis was 387rwhp on a spike at the end of the dyno, so really 375ish. his non tuned dyno run was 360rwhp if I remember. so, 15hp for tuning. (about right) 25 hp for cams with 1mm more lift, and some other small tweaks. sounds about right.
my car had a very vented air box as well. the same engine bone stock, with no modifications at all, but without a cat, was 290rwhp, so it was strong to begin with, unless that number was aided by the cat missing, plus remember, it had GT cams. (or something very GT like)
Old 11-29-2010, 05:32 AM
  #35
Dennis K
Dennis K's Avatar
Sharktuning (lots of it) helped. We did a significant amount of tuning before we ever went to the dyno. I ran 3 different MAFs and all three read differently. They're supposed to be calibrated to a curve designated by Bosch, but we didn't find that to be true.
Prior to our dyno sessions, we did several runs with wide-open throttle acceleration in 3rd & 4th gear with the purpose of getting everything into a safe air:fuel ratio. I had Bill Ball in the passenger seat w/ a laptop making adjustments to the Sharktuner maps in realtime.
Then over the course of four sessions at the dyno, Jim was able to refine the tuning. We took data from the Sharktuner logs and from the Techedge wideband O2 logs to make decisions on the changes to make to the WOT and closed loop maps.
Below is the delta over the dyno tuning sessions. We gained over 50 lb-ft of torque at various rpm, but compared to completely untuned, I'm sure we gained even more. If we had installed cams and dyno'd without any Sharktuning at all, the difference would have been greater.
Old 11-29-2010, 01:35 PM
  #36
mark kibort
Its too bad we couldnt see the untuned versions. what was bill changing during the non-dyno tunine runs? were those changes hp gainers you think. then, on the dyno, what did you tune differently than what you did in the in-car driving runs? Im amazed of the changes on the dyno run. 25hp average and about the same at peak. not bad.
sorry, your at about 380rwhp, not 375, due to that noise as I said before. you are at 375 at 6k! pretty amazing, really!
Old 11-29-2010, 01:59 PM
  #37
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,718 Likes on 1,319 Posts
Getting interested in Sharktuning, Mark?
Old 11-29-2010, 02:01 PM
  #38
mark kibort
as soon as anderson sends me hacked up tuning port connector with the wires hanging off it. mine are just in a bundle with tape around the. holbert car legacy issues.
Quick Reply: S3 cams in an S4
