928sRus WINTER SPECIALS - X Drilled Rotors & Ignition Parts
#61
Brad.........get yourself some high temp paint and when you have the kitchen to yourself:
#62
Chronic Tool Dropper
FWIW, the red stud can be any one of the five. Factory put the red spot on one [random] stud so that it would be easy to get the wheel on the same rotation every time. Chasing a vibration or imbalance, and especially when using on-the-car balancing, it would be a shame to lose that accuracy when removing and repacing a wheel for something simple like cleaning or inspection.
#63
Thanks Jim!
To tell if you have BIG blacks/big reds or standard S4 brakes on the front, measure the pads. The S4 pad is 48mm tall, the big Red/Black is 58mm tall (not long). Also the rotor for the S4 has a 304mm diameter the Big Red/Black is 322mm in diameter.
Hope this helps, and Sean, we were all noobs once!
#65
#66
so ILL take the
Set of four X-Drilled Zimmerman Rotors for the 86.5 to 91 cars.
$425 plus shipping.
and how much did you say the pads are.
#68
Basic Sponsor
Hi Brad,
Sent you an email.
Roger
Sent you an email.
Roger
