Can I Leave WBO2 Sensor in w/o Powering It?
I am going to be installing and working with the Innovate LM-2 sometime next week. I read somewhere, but now I cant find it, that you shouldn't leave the WBO2 sensor in the exhaust stream without it being powered up.
After doing some data logging, I wasn't planning on leaving the LM-2 connected but was going to leave the WBO2 in the X-pipe.
Anyone know?
Thanks.
Glen
Anyone know?
Thanks.
Glen
Archive Gatekeeper
Bad idea. Either leave it powered when the car is running or remove it.
Are you Sharktuning with the LM-2 or just datalogging? If the former I'd be interested in seeing how you interfaced the LM-2 with the ST.
Rob,
Just using it to data log. I installed the Porken S300S racing chip set and want to do some logging to see if there is more to be had. Ken has tuned the chips in his car, 5 speed, mine is an auto.
Glen
Glen
Here's what I think but do not know.
The risk with leaving it in unpowered is that it becomes clogged with carbon (which would normally burn off). Not advised, but I don't think this is a guaranteed destruction.
What really kills the sensor is water. Long term exposure is one way, having the sensor pointing downwards and the water inside the pipe condensing in it is a no-no. Even quicker way to kill it, though, is to first heat the sensor before starting and then have the engine cough up some water from the exhaust on it. I think it'll pop.
If none of this succeeds in killing the sensor, you can always try prolonged exposure to leaded race gas exhaust...
Actually having the sensor in the bottom of a pipe pointed up is worse for moisture.
The heater on a UEGO or narrow-band sensor is to get the sensor warm enough to operate. This allows the engine to go into closed loop operation faster as you don't have to wait ~30 seconds for the exhaust energy to get the sensor going.
You can drive thousands of miles with an unpowered sensor in the exhaust. However, if you aren't reading it, pull it and install a bung. There is no reason to put miles on a sensor that costs $100 for no reason.
Inventor
FWIW, TechEdge says (and this is probably the same for all WBO2 sensors):
- Pump Cell sensors (like the LSU) should not be exposed to an exhaust stream and left unheated. The internal diffusion chamber will readily clog with carbon deposits that would be "burnt off" in normal operation.
- If your wideband unit is disconnected for any length of time (> 10 minutes), you should also remove the sensor and replace the nut in the bung.
